5 axis tilted drilling
07 Oct 2022 12:50 #253686 by Aciera
Replied by Aciera on topic 5 axis tilted drilling
iI allready create several configurations in 2.7 and 2.9 versions .The resault is always the same:If the axis named C it want work
If the axis named A works perfekt(exakly the same config)
Really not sure what is going on.
Just as a work around you could try to add an A axis and increase the number of joints to 7 in the ini file and see if that gets the C axis going.
07 Oct 2022 13:05 #253688 by Aciera
Also to keep things simple until you get the C axis running you might want to change back to trivial kinematics.
so in your ini file, instead of
KINEMATICS = 5axiskins coordinates=xyzcbw
revert back to
KINEMATICS = trivkins
07 Oct 2022 13:31 - 07 Oct 2022 13:32 #253694 by Aciera
I assume you have tried jogging the C axis with the '+' and '-' in the axis gui. Or are you trying to jog with the keyboard only?
edit:
Also, have you tried if the C axis works in MDI command?
Last edit: 07 Oct 2022 13:32 by Aciera.
08 Oct 2022 05:41 #253731 by Yannis
Replied by Yannis on topic 5 axis tilted drilling
yes
no
08 Oct 2022 05:42 #253732 by Yannis
i will try that
08 Oct 2022 05:59 #253734 by Yannis
File Name: linuxcnc.report.txt
File Size:5 KB
08 Oct 2022 06:49 #253735 by Aciera
check_config: (trivkins kinematics) ERROR:
[JOINT_3]MIN_LIMIT > [AXIS_A]MIN_LIMIT (-9999.01 > -1e99)
[JOINT_3]MAX_LIMIT < [AXIS_A]MAX_LIMIT (9999.01 < +1e99)
[JOINT_5]MIN_LIMIT > [AXIS_C]MIN_LIMIT (-10 > -9999.01)
[JOINT_5]MAX_LIMIT < [AXIS_C]MAX_LIMIT (20 < 9999.01)
You have your AXIS limits set larger than your JOINT limits. Try setting equal limits for axis and joints
08 Oct 2022 07:36 #253738 by Yannis
i try to set xyzabcw and xyzabc config
the error result
File Name: my_LinuxCN...08-2.ini
File Size:6 KB
File Name: linuxcnc.r...08-2.txt
File Size:8 KB
File Name: my_LinuxCN...08-2.hal
File Size:16 KB
08 Oct 2022 11:59 - 08 Oct 2022 12:01 #253746 by Aciera
Ok maybe try the attached files. I have fixed some stuff in your hal and omitted the a-axis there since we only want that in the ini to test things.
Last edit: 08 Oct 2022 12:01 by Aciera. Reason: edit ini file
The following user(s) said Thank You: Yannis
10 Oct 2022 06:01 #253847 by Yannis
 Hello
the resault with the latest file
File Name: linuxcnc_i...0-10.txt
File Size:3 KB
File Name: linuxcnc.r...0-10.txt
File Size:8 KB
Time to create page: 0.237 seconds
