Can you translate the program? If yes how
10 Oct 2022 12:35 #253873 by George777
Replied by George777 on topic Can you translate the program? If yes how
So i would be able to download the iso with gmoccapy?
And just to be sure:
Gmoccapy is jsut a "theme/skin" for linuxcnc? Configs of axes should work on both linuxcnc bare and on gmoccapy?
10 Oct 2022 12:37 #253874 by andypugh
Replied by andypugh on topic Can you translate the program? If yes how
Yes, once you have a workking config you can swap the GUI in use by simply editing the INI file [DISPLAY]DISPLAY= entry.
10 Oct 2022 12:39 #253875 by George777
so i have to downlaod different iso in order to get gmoccapy or i can just change to config like you said here?
10 Oct 2022 12:42 #253876 by andypugh
If you already have a LinuxCNC installation, just change the INI to select Gmoccapy.
linuxcnc.org/docs/stable/html/config/ini...tml#_display_section
10 Oct 2022 14:17 #253884 by George777
Do you know the config location?
10 Oct 2022 14:21 #253886 by George777
found it
10 Oct 2022 14:48 #253888 by George777
Thank you so much....
Lst thing how can i translate it?
10 Oct 2022 14:57 #253890 by andypugh
Possibly here would be best
hosted.weblate.org/projects/linuxcnc/gmocappy/
But, wait for confirmation from someone more up-to-date with the current translation infrastructure.
10 Oct 2022 16:49 #253894 by HansU
Replied by HansU on topic Can you translate the program? If yes how
Yes that's correct. But only for the master branch (LinuxCNC 2.9).
Which version are you using?
And to which language do you want to translate?
10 Oct 2022 17:07 #253896 by George777
2.8.4
Time to create page: 0.136 seconds
