Servo interface
- Thank you received: 5308
04 Oct 2022 14:27 #253452
Replied by PCW on topic Servo interface
7I77 firmware is available for a 7I80DB
To use pncconf to create a hal/ini file set, I would create a config for
a 7I92+7I77 and then change the card name in the ini file
- eslavko
07 Oct 2022 05:58 #253645
by eslavko
Replied by eslavko on topic Servo interface
7i92+7i77 doesn't work in pnconf!
I can set number of encoders, but cant set numbers of PWM generators.
- HansU
- Thank you received: 217
07 Oct 2022 07:50 - 07 Oct 2022 07:50 #253651
by HansU
Replied by HansU on topic Servo interface
You can also try with Mesa Configuration Tool: gnipsel.com/mesa/mesact/index.html
Still in development, but is working fine in most cases
Last edit: 07 Oct 2022 07:50 by HansU.
- eslavko
07 Oct 2022 07:56 #253652
by eslavko
Now I fell stupid. Seems to be normal to 7I92 doesn't have PWM generators. But it have SmartSerial where I can acess PWM generator on 7I77. I just looked on wrong place.7i92+7i77 doesn't work in pnconf!
Time to create page: 0.185 seconds
