QTplasmaC wont turn on
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
05 Oct 2022 02:40 - 05 Oct 2022 02:55 #253488 by bevins
Replied by bevins on topic QTplasmaC wont turn on
upgrading now........
Last edit: 05 Oct 2022 02:55 by bevins.
05 Oct 2022 03:10 #253489 by rodw
Replied by rodw on topic QTplasmaC wont turn on
Bevins if you are using an external safety circuit with a hardware reset button, set the estop mode to indicator only and it should work.
I have got it going on a controller at home. So I'll try and remember to look for you.
QTplasmac is definitely not the same as axis with estop but it seems to work OK for me.
05 Oct 2022 05:37 #253498 by cmorley
Replied by cmorley on topic QTplasmaC wont turn on
I did make some progress towards AXIS like behaivor on the estop button. Not sue if Qtplasmac supports it or not.
  • bevins
  • Platinum Member
  • Platinum Member
05 Oct 2022 11:07 #253518 by bevins
I upgraded and it worked. IT wasn't the estop. I really don't know what it was. Probably like snow said. upgraded and imported config didn't work.
It is working now. Thanks as always for support here.
Have a great day.
The following user(s) said Thank You: tommylight, snowgoer540
  • snowgoer540
  • snowgoer540's Avatar
  • Moderator
  • Moderator
05 Oct 2022 11:56 #253519 by snowgoer540
Replied by snowgoer540 on topic QTplasmaC wont turn on
Happy cutting!
  • bevins
  • Platinum Member
  • Platinum Member
18 Oct 2022 23:11 #254476 by bevins
So I finally got it back up and working kind of. The X axis is vibrating crazy like. Mechanically it seems to be sound. Power off it moves smoothly.
I upgraded the computer and copied the config folder and got it updated. Thats when it started to do this. Is there something that could be causing this in the hal file?
I am at a loss on this one. This is the gantry axis. Both motors are doing it.
  • Moderator
  • Moderator
18 Oct 2022 23:25 #254478 by tommylight
Replied by tommylight on topic QTplasmaC wont turn on
Check the PID values, P should be 1000 for a normal servo period of 1ms, FF0 should be 1, the rest 0.
Granted that is for a step/dir system and Mesa boards.
Also, sometimes a line containing "maxerror" causes that, so try omitting that line for the offending joints. Do not delete the lines, i am sure PCW told us it can be useful, so i never delete it, just in case.
  • bevins
  • Platinum Member
  • Platinum Member
19 Oct 2022 14:01 #254525 by bevins
did that still the same thing.
what about previous error? Comment that also?
  • bevins
  • Platinum Member
  • Platinum Member
19 Oct 2022 14:03 #254526 by bevins
Error-previous-target true
comment that also?
  • Moderator
  • Moderator
19 Oct 2022 16:58 #254540 by tommylight
Depends on how old the installation is, i am sure i had to do that for a while, but not lately for sure.
Make a video, might be able to tell from the sound.
Time to create page: 0.138 seconds
