- LinuxCNC
- General LinuxCNC Questions
- After new install of Linuxcnc axis motors not working (same config)
- denhen89
- Thank you received: 27
13 Oct 2022 11:18 #254063
by denhen89
After new install of Linuxcnc axis motors not working (same config) was created by denhen89
Hello,
after problems with my Linux i decided to save my configuration and reinstall Linux.
I used the 2.8.2 Linux installer, but then after i found out about the not working axis motors i upgraded to 2.9, which did not fix the problem.
I am using the exactly same config as before the linux problem.
My physical buttons and potentiometers are working fine, spindles starts and stops, etc. but when i want home, my motors just dont move, but they are powered.
I am using GMOCCAPY.
I uploaded all my files as .RAR, i hope thats fine and i hope someone can help me out with that.
I am getting no error messages when starting LinuxCNC, so i do not understand why the motors are not moving when using the previously working configuration without any changes.
- Thank you received: 7462
13 Oct 2022 12:11 #254069
Replied by tommylight on topic After new install of Linuxcnc axis motors not working (same config)
Not exactly the same config, you opened it in PncConf and that will overwrite stuff.
Answered on the other topic.
forum.linuxcnc.org/38-general-linuxcnc-q...ogin?start=10#254067
- LinuxCNC
Time to create page: 0.114 seconds
