Fanuc serial encoder part numbers that work with mesa cards.
14 Oct 2022 12:39 #254113 by M4MazakUser
Anyone care to share there fanuc serial encoder part number that works with meas firmware? I have #2 encoders and have been told that I can only currently use #1 type. -type 1 being aa64, whereas type 2 are Ai64 type.
I'm looking at swapping the encoders so I can have something useful but I need a working part number so I can locate some. (If anyone has any im in Australia)
14 Oct 2022 17:18 #254125 by PCW
Are you sure you have type2 encoders?
What is the full part number of your encoder (the number that starts with 860)
15 Oct 2022 01:33 #254146 by M4MazakUser
My encoders are a860-2000-t301
as per pic. My friend
15 Oct 2022 02:48 #254149 by PCW
I'll take a look at what I have, (probably Monday) I may have that same encoder
If so, I'll see If i can make it work
18 Oct 2022 18:21 #254449 by M4MazakUser
Thanks, I've been going through the rest of the lathe in the meantime, its a Taiwanese machine, (chenho thc2050) very good quality parts. Pity about the fact that every bearing is stuffed due to it going 4m under flood mud!
18 Oct 2022 20:10 #254459 by PCW
OK the one I have is a A860-2001-T301
Pulsecoder aiA16000
But it has the same connector and I suspect it's
just the 16M count version of your A860-2000-T301
19 Oct 2022 09:08 #254500 by M4MazakUser
The count would just be a value in hal (that could be changed). The xilinx module would be the same for different counts?
19 Oct 2022 14:39 #254529 by PCW
Differing resolutions require different hal parameters for the FANUC encoder module
(so the right bit field segments can be extracted from the returned serial data)
20 Oct 2022 18:35 #254624 by M4MazakUser
So, is the bitstream the same, -77 etc, is it just an increase in frequency. Is there consistent position data being sent out as there is only rd and *rd pins ?
20 Oct 2022 18:50 #254626 by PCW
I don't know the data length yet. It may well be longer.
Hoping to have some time to experiment with my encoder next week
Time to create page: 0.132 seconds
