Pulse index
  • Moderator
  • Moderator
18 Oct 2022 09:02 #254383 by tommylight
Replied by tommylight on topic Pulse index
From the picture, i am pretty sure the sensor is not counting holes, just the missing part, it is to far back.
So it is only as index as is.
Use the "show hal configuration" from the machine menu to watch the sensor pin and see if it is counting only once per revolution or multiple times.
The following user(s) said Thank You: Turners
18 Oct 2022 10:54 #254390 by Turners
Replied by Turners on topic Pulse index
Do I have to change the pin?
how do I show hal configuration I'm getting there learning
How do I get that pin to pulse
Do you run in terminal window to make your changes.?
Time to create page: 0.079 seconds
