- LinuxCNC
- General LinuxCNC Questions
- What are the Problems with Using Debian for a Machine Controller?
- Bari
- Thank you received: 234
10 Dec 2022 18:57 #259122
by Bari
What are the Problems with Using Debian for a Machine Controller? was created by Bari
What are the Problems with Using Debian for a Machine Controller? Lots of people are avoiding Debian and trying to use Mint, MX, Manjaro etc etc with LinuxCNC for various reasons. What are your reasons?
What needs improving, fixing, replacing or removing in Debian?
- Pain the butt to kill screen blanking, sleep or screen saver in some versions.
- Graphical network managers always somehow broken. Won't fix.
- Wired Networks are Unmanaged As of Debian 6.0 "Squeeze" . wiki.debian.org/NetworkManager#Wired_Networks_are_Unmanaged
- After each reboot there is another network manager icon in the taskbar with XFCE
- Kernels too old for brand new hardware
- Too many unused services are left on that a machine controller just doesn't use
- Desktops can take a long time to load (>1 minute) with AMD CPUs (XFCE, LXDE)
- JT
- Thank you received: 583
10 Dec 2022 19:05 #259124
by JT
Replied by JT on topic What are the Problems with Using Debian for a Machine Controller?
I use Debian Mate and don't have any of the issues you do.
It does take me about 5 minutes to fix all the annoying things Debian developers "think" we need.
gnipsel.com/linuxcnc/debian-11-fix.html
JT
JT
The following user(s) said Thank You: Bari
- JT
10 Dec 2022 19:09 #259125
by JT
It does seem silly to have fcitx with chinese stuff on a machine setup for English so I remove it pretty quick with sudo apt remove fcitx*
JT
What services are you talking about?
JT
- Bari
10 Dec 2022 19:16 - 10 Dec 2022 19:20 #259126
by Bari
Replied by Bari on topic What are the Problems with Using Debian for a Machine Controller?
Thank you for posting your fixes for Debian -11 with Mint.
I don't expect the Debian devs to fix or change anything. I'm just generating a list of reasons why people look elsewhere for Linux for use with LCNC.
Last edit: 10 Dec 2022 19:20 by Bari.
- Thank you received: 7462
10 Dec 2022 20:40 #259132
Replied by tommylight on topic What are the Problems with Using Debian for a Machine Controller?
I use Debian with XFCE for some mills, Debian with Mate for some plasma, and Mint Mate for all my machines.
-Debian takes much longer than Mint to boot,
-Debian sometimes messes up updates/upgrades, very rare lately
-Debian works, and works very good for years and years
None of the reasons here should deem it unusable as far as i am concerned.
And, just to add to the mess, Ubuntu 10.04 was a tank in all respects, if you did bot have the luck to be using Intel 815 chipset!
- Thank you received: 4138
10 Dec 2022 21:58 #259138
Replied by rodw on topic What are the Problems with Using Debian for a Machine Controller?
None of these are an issue with Debian Bullsye and above. XFCE is required for the CNC menu to appear.
The only issue that requires an edit to text files is the autologon which differes between xfce and the default debian desktop.
The biggest issue is network latency causing error finishing read if using a mesa card and a realtek NIC.
Some of john's tweaks I have never heard of....
- Bari
10 Dec 2022 22:07 #259142
by Bari
"All graphical network managers (including wiwfi) work even on xfce.
The only issue that requires an edit to text files is the autologon which differes between xfce and the default debian desktop."
Thank you. Do you have a link for the fix to this issue? Which desktop is the default Debian desktop? Does it prevent a new network manager icon from appearing after each reboot in XFCE? If it's a simple fix for XFCE why don't the devs fix it?
Why do you suppose that some many people are trying LCNC on other distros?
10 Dec 2022 23:59 #259163
Debian desktop is gnome.
you can install other desktops with tasksel
You can select the desktop from the logon page (gear at bottom right)
Recent attempts have seen linuxcnc fail to load from the packaged bookworm install on the default desktop as its on Wayland (but it used to work)
There is a Xorg version of gnome that I think solves that issue.
Gnome does not use lightdm as xfce does so autologin is different. ref:
help.gnome.org/admin/system-admin-guide/...in-automatic.html.en
For me, I've tried it on Arch llnux to avoid the debian network latency issue. Which it did but it was hard work!
Back before PREEMPT_RT was available in Debian or the original LCNC stretch iso, We had to compile the kernel to get it. It was not much more work to build linuxcnc from source. At the time, the 2.7 iso was awful for usability so we used Mint.
Currently a lot of hardware requires kernel 5.10 or above (eg Bullseye). Mint et al lagged a long way behind with kernels until very recently so it did not have the required Python version for V2.9
With the packaging in Bookworm, I've tried hard to stay with Debian for ease of install (on bookworm)
Really I think the reason recently so many options have emerged is because there is no ISO for Bullseye which has the drivers people need.
The following user(s) said Thank You: Bari, tommylight
- Bari
11 Dec 2022 00:20 - 11 Dec 2022 00:25 #259165
by Bari
I have installed Bookworm and Bullseye using the XFCE ISO's. For example:
cdimage.debian.org/debian-cd/current-live/amd64/iso-hybrid/
cdimage.debian.org/debian-cd/current-liv...1.5.0-amd64-lxde.iso
Is this why I might be having problems with desktop load times and the network manager multiplying at each reboot and similar? Are they only "almost working" installers? It sounds like you use a gnome ISO and then change or add other desktops. Is this the way a Debian install should be done to avoid my issues?
Last edit: 11 Dec 2022 00:25 by Bari.
11 Dec 2022 01:08 #259171
Looks like those links are to bullseye so you need to upgrade to Bookworm which is time consuming.
I install the Bookworm non-free version from here.
cdimage.debian.org/cdimage/unofficial/no...-including-firmware/
Previously from the weekly builds or more recently from the alpha branch which will become the official bookworm release now its been decided to include the non-free firmware as part of it.
I go with the iso-cd net install so you don't later get caught having to edit sources.list to remove the cd repos. You do need internet access
In the install, you get a chance to choose the desktop(s) you want to install.
The text based (non-graphical) installer uses tasksel to select the desktop. You can use it later to add or remove desktops by:
sudo apt-get install tasksel
sudo tasksel.
I think from now on I'll only install xfce.
I suspect compatibility with Wayland needs to be addressed with our current builds...
sudo tasksel.
- LinuxCNC
Time to create page: 0.152 seconds
