Gentoo Image, Which Applications are in and Which are Out
- NTULINUX
- Thank you received: 84
22 May 2023 01:13 #271895
by NTULINUX
Replied by NTULINUX on topic Gentoo Image, Which Applications are in and Which are Out
Those should work with the new kernel config I just crafted, added a lot of others too since I now know that this is a major requirement.
- Bari
- Thank you received: 234
14 Sep 2023 00:54 #280689
by Bari
Replied by Bari on topic Gentoo Image, Which Applications are in and Which are Out
- NTULINUX
14 Sep 2023 21:46 #280789
by NTULINUX
Please let me know of any missing features or problems. The kernel is not as generic as the Debian kernel but should give better performance and lower latency. The installer and the Gentoo image has not been extensively tested on various hardware, I expect there to be a few gotchas here and there.
Thanks guys!
Thanks guys!
- Thank you received: 4127
15 Sep 2023 11:15 #280828
Replied by rodw on topic Gentoo Image, Which Applications are in and Which are Out
I just ran through this thread's history and noted you are including qtpyvcp.
Now they have their own repository, you might also like to just include the repository sources, rather than building the full code.
Also Ethercat has its own repositiories now and I packaged the linuxcnc ethercat driver in my Debian 12 installer
You might like to review hooks 050, 0520, 0530 in my installer.
github.com/rodw-au/linuxcnc-live-build/t.../config/hooks/normal
- Bari
13 Jul 2024 18:41 #305100
by Bari
Not real pressing news but we wanted qtpyvcp built and ready to go since we use it to build custom GUI's.
- NTULINUX
14 Nov 2024 16:47 - 17 Nov 2024 02:39 #314468
by NTULINUX
LXQt is most likely going to be pulled out in the next release as I'm currently having major problems with it. XFCE 4.20 pre-release is actually quite stable though so that's a no-brainer
edit: LXQt problem is fixed for now, will be included in the image.
Last edit: 17 Nov 2024 02:39 by NTULINUX.
- NTULINUX
30 Nov 2024 13:40 - 02 Dec 2024 13:24 #315650
by NTULINUX
The mainline 6.12 kernel has the i915 DRM (Direct Rendering Manager) driver has been disabled if PREEMPT_RT is selected in Kconfig. I guess the fixes for the i915 driver that were in the PREEMPT_RT kernel patch have not made it into mainline, so the driver has been forcibly disabled for now. The newer Intel Xe driver on the other hand is perfectly fine. Hardware acceleration will not work on Intel GPUs that are not covered by the Xe driver. When i915 has been re-enabled, I will push a new Gentoo image with the driver on.
git.kernel.org/pub/scm/linux/kernel/git/...Kconfig?h=v6.12.1#n6
config DRM_I915 depends on !PREEMPT_RT
I have however set the Xe Intel driver force_probe feature to "*" which enables the Xe driver for all known devices.
www.phoronix.com/review/intel-xe-benchmark
"This driver is designed just to support Intel Tigerlake Gen12 graphics and newer -- both integrated and discrete graphics moving forward. "
Also, this will _not_ be the case in the kernel I built:
"With the Xe DRM driver in Linux 6.8, the driver remains disabled by default for all released Intel integrated and discrete graphics hardware. Even when building the Intel Xe driver to be part of the kernel, it will be off by default with the long-used i815 kernel driver remaining the default. But it is easy to switch to this new driver when the Xe driver is included. Via boot parameters like "i915.force_probe=!56a2 xe.force_probe=56a2" is enough to prevent loading of the i915 driver and loading instead the experimental Xe driver, assuming your PCI graphics ID is 0x56a2. Just adjust for your appropriate Intel PCI graphics ID and from there it's easy to boot with this new kernel driver."
You will not have to specify IDs in the kernel command line in order to use the Xe driver as this has been enabled already in Kconfig.
Sorry for the inconvenience, I know a lot of you may be running older i915 hardware. I'm going to test this on an Intel laptop to make sure X at least works with the proper display resolution, but hardware 3D acceleration may not work for some of you.
edit: Just cloned the linux-rt-devel git repository, switched to the 6.12.y-rt branch, pulled in the 6.12.y branch from stable to update it, so the i915 driver has been re-enabled. 6.12.1 with i915 is a go! The PREEMPT_RT kernel patch series hasn't been updated since 6.12-rc4, so that's fixed.
edit 2: The 6.12 mainline kernel, while has PREEMPT_RT enabled, is actually a bit useless because real-time applications check for /sys/kernel/realtime including LinuxCNC. This patch is required for LinuxCNC to work with real-time POSIX threads:
git.kernel.org/pub/scm/linux/kernel/git/...be0b95341fdc7ef1c193
So I'll be maintaining my own 6.12 real-time kernel repository that also allows building with the -O3 flag.
All is well!
All is well!
Last edit: 02 Dec 2024 13:24 by NTULINUX. Reason: i915 is back on!
The following user(s) said Thank You: tommylight, Aciera
- royka
- Thank you received: 135
02 Dec 2024 16:07 - 02 Dec 2024 16:57 #315802
by royka
Replied by royka on topic Gentoo Image, Which Applications are in and Which are Out
Deleted... Oops didn't read carefully
Last edit: 02 Dec 2024 16:57 by royka.
- NTULINUX
02 Dec 2024 18:11 - 10 Dec 2024 16:42 #315817
by NTULINUX
The kernel is up! 6.12.1 fully patched with the entire PREEMPT_RT patch set, so i915 is back online:
github.com/NTULINUX/linux
-O3 is good to go as well.
edit: New kernel repo:
github.com/NTULINUX/linux/tree/ntulinux/linux-6.12.y-rt
Last edit: 10 Dec 2024 16:42 by NTULINUX. Reason: new kernel repo
- royka
02 Dec 2024 19:31 - 02 Dec 2024 20:01 #315824
by royka
Last edit: 02 Dec 2024 20:01 by royka.
The following user(s) said Thank You: NTULINUX
Time to create page: 0.214 seconds
