RaspberryPi 4 GPIO - Use internal Pull-Up/Down Resistors
3 years 10 months ago #260514 by Maschde
Hi everyone,
i am currently using a RaspberryPi 4 for my DIY 3-axis CNC mill.
At connecting my sensors to the GPIOs i noticed that some inputs are per default high, others low.
I can't find a function anywhere in hal_pi_gpio.c that sets the internal resistors.
In the included "bcm2835.h" a function declaired but it seems that this is not used.
Is it possible to set the resistors in hal_pi_gpio.c?
I know that GPIO 2 and 3 are exceptions because of the permanently installed resistiors.
Thank you guys
3 years 10 months ago #260539 by elovalvo
Unfortunately it is not possible, at the moment, to set the resistors directly from hal_pi_gpio.
The solution I use
forum.linuxcnc.org/9-installing-linuxcnc...ware-stepping#260086
is to use a command file (initgpio.txt), based on the raspi-gpio command
github.com/RPi-Distro/raspi-gpio
to run before launching LinuxCNC
3 years 10 months ago #260624 by Maschde
Thank you very much, i will try it.
I think i get it working.
Time to create page: 0.284 seconds
