- Thank you received: 6
Joint on limit errors only when G540 is active
- trainwreck
- Topic Author
3 years 10 months ago #260575
by trainwreck
Joint on limit errors only when G540 is active was created by trainwreck
I just got my machine configured and have tested everything using hal meter/hal show. It is an xyyz machine, and I can jog all axes (although only one of the Y joints) through the pncconf axis test dialog. Using the hal meter, I have confirmed that all 4 of my inductive limit/home (shared) switches are on the pins I expect them to be on, and they read false until I move some metal near them. I'm using a Gecko G540 for motor drivers, and a Mesa 7i92 with a Mesa 7i75.
The confusing part is I can turn on the machine in linuxcnc just fine as long as the G540 is not active. Once the G540 turns on - or if I try to turn on linuxcnc with the G540 already on, linuxcnc throws a random amount of "join on limit" errors, and sometimes "could not switch the machine on, is limit switch activated?" error as sown in the first image. If I turn on linxcnc with the G540 off, then everything works as I would expect. I can even manually trigger the limit switches as shown in the second image.
I have tested all of the pins with the hal meter when the G540 is on and even then it still sees the pins as false, so I really think there must be something unrelated wrong with my configuration that I just don't realize. Does anybody have any idea why this might be happening?
3 years 10 months ago #260580
Replied by PCW on topic Joint on limit errors only when G540 is active
Random errors sounds like a electrical noise issue
How are the limit switches sensed? (via the G540 input or 7I75 inputs?)
- trainwreck
- Topic Author
3 years 10 months ago #260587
by trainwreck
Replied by trainwreck on topic Joint on limit errors only when G540 is active
Sorry, I don't mean the errors randomly happen, they happen 100% of time as described. The randomness is in how many of the joints show up with errors.
The sensors are on the 7i75 inputs which is why I'm so surprised that they react differently if it's on or off.
3 years 10 months ago #260590
I would still suspect electrical noise issues
You may need better signal shielding and or
debouncing of the hal signals to eliminate impulse noise
To check for noise, try plotting the limit switch signals with halscope
- trainwreck
- Topic Author
3 years 10 months ago #260600
by trainwreck
I checked in the Hal scope as best as I am able, given I know nothing about how to use it (or any scope). Attached is a picture of the rising edge of a sensor trigger, it looks clean to me.
It did make me realize that these are 6-36v sensors though, and I expect that's a problem considering the 7i75 is meant for 5v logic. I'd that is a problem, is the a simple solution to make these work, or will I need to just buy appropriate sensors?
- trainwreck
- Topic Author
3 years 10 months ago #260681
by trainwreck
Now that I have been able to spend more time in the shop testing, I believe PCW is correct about electrical noise. While the G540 is active the switch states bounce like crazy, I can even seem them blinking between triggered and untriggered in the Linuxcnc preview window while in the power off state. There is also some strangeness with the watchdog timer where the G540 will not recognize the timer when the power on button is pressed (and so stays in fault) but if I toggle the watchdog off and back on then it will recognize the signal and stay active until I power off Linuxcnc.
I can't really understand why this would be the case unless it has something to do with the 12v -> 5v conversion that's happening on the 7i75. I have used this G540 board successfully with 5V mechanical switches for years before now, using unshielded cable the same as they are now. I really hope I don't need to fish these out of my drag chains and buy new, expensive shielded cable
I am unfortunately pretty far out of my depth, so hopefully some of you fine folks will have some ideas for me!
Time to create page: 0.164 seconds
