Retrofitting Realmeca need help
- Arnaud
21 Mar 2023 14:15 #267232
by Arnaud
Replied by Arnaud on topic Retrofitting Realmeca need help
- Arnaud
23 Mar 2023 10:57 #267350
by Arnaud
I have disable everything with power or sleep
- Thank you received: 7461
23 Mar 2023 12:22 #267361
Replied by tommylight on topic Retrofitting Realmeca need help
Disable aslo
Hyperthreading
C states
Virtualisation
TPM
Sata power management if using SATA drive
PCI-E power saving
Speed step
Turbo
Etc.
Hyperthreading
C states
Virtualisation
TPM
PCI-E power saving
Speed step
Turbo
Etc.
- onceloved
- Thank you received: 59
27 Jun 2023 14:24 #274306
by onceloved
Replied by onceloved on topic Retrofitting Realmeca need help
Do you need to delete the base_period in the ini file if you control the bus servo driver through ethercat?
Time to create page: 0.106 seconds
