Spindle as Joint or Spindle
3 years 7 months ago #266795 by GaryLa
Hello,
I worked with LinxuCNC for several years a while back. I had been working on a proprietary system at work for the past few years. Now I'm back to using LinxuCNC and have to admit a lot of the little nuances I thought I'd never forget, I forgot.
I've converted a lathe to CNC and chose to use Teknic motors throughout, including the spindle. The one thing I don't like about Teknic motors was their lack of foresight on making the internal encoder available as an output -- at least the index pulse. But that's a gripe for another day.
I'm wanting to use the 2 HP 220V "stepper" as my spindle motor. But I would also like to use it as a C axis from time to time since I have live tooling.
I figure I will need two different INI/HAL configurations to implement this, but I'm unclear on how to run the spindle as a "stepper" but responding to M3, M4, M5 and S commands. So far it seems that without an encoder input, I cannot accomplish this. Or rather, I can't get any useful lines emitted into the HAL file by PNCCONF.
As the C axis, I assume it's not going to be a problem, as I assume I can just assign it to an axis stepgen as I have with X and Z.
Any insights would be greatly appreciated.
3 years 7 months ago - 3 years 7 months ago #266799 by JPL
Replied by JPL on topic Spindle as Joint or Spindle
I believe you really need to have access to the encoder signal but since you definitively need an index pulse per turn for threading I would suggest to add an external encoder, especially if you don't have access to the signal from the internal encoder of the spindle motor.
Now it is certainly possible to have both S and M3,M4, M5 commands from a single INI/HAL configuration.
Talla83 did this a while ago. See here www.talla83.de/ Have a look at video #14 and $15. Now, there's at least 3 difficulties:
- Its in German (with almost useless translation from youtube)
- Its made for linuxcnc v2.7 which need to be modified to run under 2.8 and up
- Its somewhat specific to the hardware he is using.
You can also do a search with 'spindle orient', which should bring up many discussions about this topic and also look at the orient component: linuxcnc.org/docs/html/man/man9/orient.9.html
Good luck
Last edit: 3 years 7 months ago by JPL.
3 years 7 months ago - 3 years 7 months ago #266800 by JPL
... Some info here too: wiki.linuxcnc.org/cgi-bin/wiki.pl?SpindleOrient
EDIT: But then maybe not.... humpff...  All this was for spindle orientation, not the same thing as spindle as C axis... My bad.
image missing /media/kunena/emoticons/unsure.png
3 years 7 months ago - 3 years 7 months ago #266827 by GaryLa
Replied by GaryLa on topic Spindle as Joint or Spindle
Thanks for the reply. I have managed to thread using a spindle as C with commands like:
G1 C[360.0 * 8] Z[0.0625 * 8]
Inside a loop, rewinding C and Z, and moving X inward as required, rinse, repeat. It doesn't matter where the spindle starts as long as Z starts with it and the spindle and Z can be rewound to the same positions.
What I'm not getting is exactly how to generate the HAL code to rotate the spindle using step pulses. I've seen some snippets here and there, but I'm unclear as to how many items need to be connected in the HAL for this. I've seen the following threads which are close:
forum.linuxcnc.org/49-basic-configuratio...d-mesa-card?start=10
forum.linuxcnc.org/24-hal-components/463...an-encoder-m19-g33-1
But what I was hoping for was an output from PNCCONF that I could then tweak. It appears it doesn't output anything when the spindle is assigned to a StepGen Spindle. I'm using version 2.8.4.
Last edit: 3 years 7 months ago by GaryLa. Reason: typo
3 years 7 months ago - 3 years 7 months ago #266832 by GaryLa
Apparently, if you specify an encoder (which I don't have), PNCCONF will output the step gen information required in both the INI and HAL files.
I wasn't specifying one, because I don't have one, and I was literally getting only 3 lines of HAL code regarding the spindle and nothing in the INI.
Now I *think* the challenge will be to use the step gen itself as the "encoder" data. I think the answer lies here:
Probably a emulated index comp that takes position (say stepgen FB position),
mods by one and simulates the index logic would do all thats required
Has anyone seen an example of this? Perhaps the component to use is the "sim-encoder" ?
Last edit: 3 years 7 months ago by GaryLa. Reason: updated
3 years 7 months ago #266885 by JPL
Found something that I think is pretty close to what you want: forum.linuxcnc.org/24-hal-components/388...index-for-simulation
The following user(s) said Thank You: GaryLa
Time to create page: 0.389 seconds
