QtVismach installation in Linuxcnc (debian wheezy)
04 Apr 2023 06:25 - 04 Apr 2023 06:29 #268240 by fery15sty
Hello can help me..
how to install Qt Vismach panel in AXIS gui, I use Linuxcnc (Debian Wheezy)
I tried to enter the script:
######################!/usr/bin/env python3
import hal
import math
import sys
from qtvcp.lib.qt_vismach.qt_vismach import *
etc
Last edit: 04 Apr 2023 06:29 by fery15sty.
04 Apr 2023 16:36 - 04 Apr 2023 16:36 #268270 by cmorley
This seems like an error message related to python version.
What version of linuxcnc are you using?
I dont think I have tried qtvismach with python 2 but it's probably possible.
Last edit: 04 Apr 2023 16:36 by cmorley.
The following user(s) said Thank You: fery15sty
05 Apr 2023 02:09 #268312 by fery15sty
I using linuxcnc 2.7.15 in debian wheezy.
Maybe the qt vismach library needs to be added?
05 Apr 2023 02:15 #268313 by fery15sty
I had python 3.2 installed when I tried it.
Are there certain libraries that need to be downloaded? maybe qt-vismach library??
05 Apr 2023 02:23 #268314 by cmorley
I do believe linuxcnc 2.7 / wheezy is too old. It might be possible with a lot of work, but I don't have a system to even try it.
If it's a need I would suggest moving up to a new version of linuxcnc, but only if it's a need.
06 Apr 2023 02:46 - 06 Apr 2023 03:00 #268373 by fery15sty
Ok.. i have installed debian 10. but i can't move vismach simulation to axis tab like your example..please guide me step by step, what should i do?
Last edit: 06 Apr 2023 03:00 by fery15sty.
06 Apr 2023 03:51 #268375 by cmorley
Is there a sim screen called:
axis/qtvcp/qtvismach_tab ?
Does it work?
06 Apr 2023 05:40 #268384 by fery15sty
No where do i find? axis/qtvcp/qtvismach_tab ?
06 Apr 2023 05:44 #268385 by fery15sty
I found several directories that contain qtvcp
06 Apr 2023 05:51 #268387 by fery15sty
Sorry my english is not good. I'm from Indonesia. English isn't my first language, so please excuse any mistakes.
Time to create page: 1.498 seconds
