Remap M6: Is this philosophy possible?
- zz912
- Thank you received: 98
06 Apr 2023 12:21 #268419
by zz912
Remap M6: Is this philosophy possible? was created by zz912
Hello,
I have done Remap M6 pro Brotherc TC-211. I made it by O-word. It worked, but it wasn't perfect. So I started learning python.
I would like to ask if it is possible to implement:
1) I will make HAL component:
2) In Remap code I would like control pins from this compontent:Is possible import component from another file.py ?
import hal
h = hal.component("atc-remap")
h.newpin("in", hal.HAL_FLOAT, hal.HAL_IN)
h.newpin("out", hal.HAL_FLOAT, hal.HAL_OUT)
h.ready()2) In Remap code I would like control pins from this compontent:
h['out'] = 1002.45Please Log in or Create an account to join the conversation.
- Thank you received: 2181
06 Apr 2023 12:50 #268423
Replied by cmorley on topic Remap M6: Is this philosophy possible?
github.com/LinuxCNC/linuxcnc/blob/master...n-stdglue/stdglue.py
This shows loading a hal component in a remap
- zz912
06 Apr 2023 13:27 - 06 Apr 2023 13:29 #268427
by zz912
Replied by zz912 on topic Remap M6: Is this philosophy possible?
Do you think this part?
def build_hal(self):
import hal
try:
h=hal.component('remapStat')
h.newpin("tool", hal.HAL_S32, hal.HAL_OUT)
h.newpin("wear", hal.HAL_S32, hal.HAL_OUT)
h.ready()
self.hal_tool_comp = h
except Exception as e:
print(e)
But this part create new component, not use exist component. Or not?
import hal
try:
h.ready()
print(e)
Last edit: 06 Apr 2023 13:29 by zz912.
06 Apr 2023 14:04 #268435
Yes it makes a new component.
- zz912
06 Apr 2023 14:24 #268436
by zz912
Is there a way to just modify an already existing component?
Or is there a way to modify this component created in remap with another python code?
I have one ATC, but a friend wants to have 2 ways of control. One automatic via M6 and the other sequential via buttons.
07 Apr 2023 00:53 #268473
You can use normal HAL commands to interact with the remap component.
What do you mean 'modify this component created in remap' ?
- zz912
07 Apr 2023 04:43 #268486
by zz912
I'll try to explain it another way.
I can change value HAL PIN by M-code like this:
forum.linuxcnc.org/38-general-linuxcnc-q...ith-g-m-codes#268483
I can change value HAL PIN own component:
But how change for example ini.x.max_limit by python?
import hal
h = hal.component("own")
h.ready()
h['out'] = 1002.45
07 Apr 2023 15:22 #268521
What version of linuxcnc are you using?
How about:
hal.set_p("pinname","10")
linuxcnc.org/docs/2.9/html/hal/halmodule.html#_set_p
The restriction there is the pin must not be connected to anything.
Another way is to have the two component pins feed into a 'steering' component (like an OR component) that then is connected to the x.maxlimit pin.
How about:
The following user(s) said Thank You: zz912
- zz912
07 Apr 2023 15:54 #268525
by zz912
I use RIP instalation Branche 2.9
I guess I already understood."pinname" is not only name of pin, but it is whole name of pin AND component.
So in my case:Is it right?
hal.set_p("pinname","10")So in my case:
hal.set_p("ini.x.max_limit","10")Please Log in or Create an account to join the conversation.
07 Apr 2023 16:28 #268527
Yes
Time to create page: 0.116 seconds
