file server for both windows and lcnc acess ??
- scotth
- Thank you received: 61
25 Apr 2023 18:08 #269877
by scotth
Replied by scotth on topic file server for both windows and lcnc acess ??
With Rockstor enable samba and install from rock_ons install (Web Service Discovery For Windows Networks). Windows will handle it as a network drive, and so will Linux. This will run on a Pi and it is free.
The following user(s) said Thank You: smc.collins
- smc.collins
- Thank you received: 139
25 Apr 2023 19:56 #269889
by smc.collins
Replied by smc.collins on topic file server for both windows and lcnc acess ??
so, get a NAS and setup samba, seems easy enough, thanks
The following user(s) said Thank You: Reddiamonduk
- Thank you received: 4138
25 Apr 2023 20:06 #269891
Replied by rodw on topic file server for both windows and lcnc acess ??
Not just a NAS, Grab a Synology NAS and its all set up. Add a user of the same name as used on your cnc box with same password
Mine is over 12 years old and still going strong and they still give me support!
Its got 9 security cameras hanging off it too
- smc.collins
25 Apr 2023 23:02 #269917
by smc.collins
I already have a standalone DVR IP camera system, I might look at one of their smaller offerings. I don't need a big massive NAS for this.
- scotth
25 Apr 2023 23:45 #269924
by scotth
Look at rockstor.com/
- JohnnyCNC
- Thank you received: 115
26 Apr 2023 01:15 #269934
by JohnnyCNC
Replied by JohnnyCNC on topic file server for both windows and lcnc acess ??
I have a Synology DS920+ with 17TB of storage. I love it. I run OpenSSH on my CNC mill and use WinSCP to send files to it. I also use WinSCP to backup my linuxcnc directory to my Windows PC.
- EW_CNC
- Thank you received: 33
26 Apr 2023 02:37 #269938
by EW_CNC
Replied by EW_CNC on topic file server for both windows and lcnc acess ??
I have a server running Linux Debian Server, headless.
With Samba file sharing between Linux and Windows.
Here are my notes on installing Samba.
Samba works good for me.
How to install Samba on Debian
**Install Samba so that files can be shared on a Linux - Windows network**
**Install:**
Do an update::
sudo apt-get update
Install Samba::
sudo apt-get install samba
Check if Samba is running::
systemctl status smbd
Open /etc/samba/smb.conf::
cd /etc/samba
ls -l
sudo pluma smb.conf
Define workgroup::
#======================= Global Settings =======================
[global]
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
workgroup = WORKGROUP
Create a Samba Share (add to end of smb.conf)::
[Share]
path = /home/smbuser/Share
available = yes
browsable = yes
public = yes
writable = yes
force user = smbuser
[NC_Files]
path = /home/smbuser/linuxcnc/nc_files
available = yes
browsable = yes
public = yes
writable = yes
Check smb.conf syntax::
testparm
Restart smbd::
sudo systemctl restart smbd
sudo systemctl status smbd
Quit smbd (press q for quit)
Install Samba_Client and list shares::
sudo apt-get install smbclient
smbclient -L localhost
Connect to Samba from Linux::
sudo apt-get install cifs-utils
**Create Static IP**
Find IP::
hostname -I
'or'
ip -c addr show
setup network manager, manual
**Install:**
Do an update::
sudo apt-get update
Install Samba::
cd /etc/samba
ls -l
sudo pluma smb.conf
Define workgroup::
[global]
[Share]
available = yes
browsable = yes
public = yes
writable = yes
[NC_Files]
available = yes
browsable = yes
public = yes
writable = yes
testparm
Restart smbd::
Find IP::
hostname -I
'or'
ip -c addr show
Time to create page: 0.106 seconds
