Delta ASDA-A2 servo drive via ModbusRTU
- besriworld
- Thank you received: 91
30 Jun 2023 17:07 #274529
by besriworld
Replied by besriworld on topic Delta ASDA-A2 servo drive via ModbusRTU
I think the best way is to leave the pid control on servo drivers . You can connect the feedback from the driver to the linuxCNC without pid connectivity. That is, if the device makes a bigger error - linuxcnc will stop the machine.My lathe will work this way.
- Spacemarine
01 Jul 2023 08:12 #274561
by Spacemarine
- Ease of installation?
- machine dynamics?
- achievable following error?
Replied by Spacemarine on topic Delta ASDA-A2 servo drive via ModbusRTU
Best way in regards to what?I think the best way is to leave the pid control on servo drivers .
- machine dynamics?
- besriworld
01 Jul 2023 13:16 - 01 Jul 2023 13:18 #274600
by besriworld
You have a high resolution encoder- 24 bit. With a well-adjusted pid regulator you have a good response - a small error. I think if you do like me.. linuxcnc will stop the machine in case of any problem with missing steps or BIG programming error(crash).
I think so, maybe someone with experience can shed some light.
Also many users complain about feedback delay from the driver. (many different brands of servo drivers with absolute encoders 17bit - 24bit) .The device must convert the feedback signal from digital to incremental.
Last edit: 01 Jul 2023 13:18 by besriworld.
Time to create page: 0.169 seconds
