How to setup probe on Mesa 7i96
3 years 5 months ago #270939 by imslo
I'm trying to set up a probe on my Mesa 7i96.  I am running +5vdc to one of the input pins.  I have the pin configured as probe in.  The probe is not working.  Should I be running +24 vdc?
3 years 5 months ago #270949 by imslo
Please disregard. I found where I asked this same question when i first installed the 7i96 on an older machine.
3 years 5 months ago #270978 by imslo
I'm sorry folks I do have a problem just the opposite of what I had before. It just plain does not recognize that a probe is hooked up. I have checked and I do have +5vdc going to input pin 1. I tried all the things I was told to do before and linuxcnc won't run if I put that stuff in the files.
3 years 5 months ago #270989 by Henry Mateo
No, +5 volts DC should be enough. Make sure the probe is hooked to the pin in the right way. If it still doesn't work, try moving the probe to a different pin and trying again.
Visit www.mesanet.com/support/knowledge-base/h...-probe-on-mesa-7i96/ to learn more about how to set up probe on Mesa 7i96.
3 years 5 months ago #271003 by tommylight
Beware that first input (or output) pin on Mesa headers is input.00 in hal, not input.01
3 years 5 months ago #271012 by imslo
I think the probe is hooked up the right way. I have +5vdc going to that pin when the probe is closed I have checked that already. It will be very difficult to get to it move but I guess I will try it. It's hook to the second input pin which is labeled 01..
Time to create page: 0.237 seconds
