How to setup probe on Mesa 7i96
3 years 5 months ago - 3 years 5 months ago #271047 by PCW
Replied by PCW on topic How to setup probe on Mesa 7i96
TB3 pin 12 is the common for inputs 0..10 (TB3 pins 1..11)
Last edit: 3 years 5 months ago by PCW.
3 years 5 months ago #271048 by imslo
I can"t find that pin in the PNCCONF Wizard TB3 page.
3 years 5 months ago #271049 by PCW
Its a physical pin that determines input operation.
Inputs will not work unless is is connected properly
3 years 5 months ago #271050 by imslo
OK I guess I will have to take the board down. I have been running this exact set up for a year. What do I put on the #12 pin?
3 years 5 months ago #271052 by PCW
TB3 pin 12 is the input common
If the input devices supply positive voltages to the 7I96 inputs
(PNP type sensors or limit switches with one pin connected to a positive voltage)
the 7I96 input common would be grounded.
If the input devices ground the signal to the 7I96 inputs (NPN type sensors
or limit switches win one pin connected to ground), the input common
would be connected to +5 to +24V
3 years 5 months ago #271053 by imslo
I see that pin on pinout. I really don't don't think I have ever used that pin before but maybe I'm wrong.
