How to setup probe on Mesa 7i96
3 years 5 months ago #271013 by rodw
Some of the probes (like the one I have) are active low. Generally the  7i96s is wired active high but you can choose to change that.
Also, my probe can handle up to 24 volts.
Sharing a link could be helpful.
3 years 5 months ago #271015 by tommylight
Use "show hal configuration" from the "machine" menu to monitor the pin the probe is attached to.
3 years 5 months ago #271029 by imslo
I am using a momentary push button switch for the probe hooked up to +5vdc. The screw on the pin where the probe is attached shows 5 volts. What link are you referring to share. Hal does not show the pin on or off. The board is not seeing the probe. The pin would show up in some of that debounce stuff I was trying yesterday. On my config file on Tab 3 pin 1 I show probe in.
3 years 5 months ago #271039 by PCW
Replied by PCW on topic How to setup probe on Mesa 7i96
Where is the input common(TB3 pin 12) connected?
3 years 5 months ago #271045 by imslo
I don't see a 12 pin. Inputs go from 000 to 010. Everything else is output.
3 years 5 months ago #271046 by imslo
I don't see a 12 pin. Inputs go from 000 to 010. (You might get this twice. I thought I had sent it but it didn't show up.)
Time to create page: 0.060 seconds
