Following errors
15 Jun 2023 12:42 #273609 by ALR85
Replied by ALR85 on topic Following errors
Apologies for that, it's now public.
The axis value changes if we spin the motor by hand with the timing belt removed
  • Moderator
  • Moderator
15 Jun 2023 12:52 #273610 by tommylight
Replied by tommylight on topic Following errors
Drives are disabled, so check for limit/home/safety/e-stop/etc switches, check power for the sensors and drive enables, fuses for said power supplies...
15 Jun 2023 13:57 #273614 by PCW
Replied by PCW on topic Following errors
Yes, sounds like the drives or analog +-10V commands are disabled somehow
27 Jun 2023 19:51 #274335 by ALR85
Hello, sorry for the delayed response. I am not based at this site and only just got back to the machine.The e stop seems to be working ok because I get the notification on the HMI when I press it in and I get error "external estop is set, could not change state" .There are 2 limit switches that also seem to be ok because i get a small symbol show up on the HMI when I press them
There are 2 breakers in the back which seem ok..there is a fuse which is good.
Photos attached of estop in and estop out, plus the limit switch symbol:  photos.app.goo.gl/tjetB8aMhgUxSHuj6
if anyone could shed some light on what to check next I would be grateful
Adam
27 Jun 2023 20:08 #274336 by ALR85
Please ignore the above.... I found another enclosure with a popped breaker. The thing runs again now.
So I'm now back at the original reported problem of it randomly stopping for X axis following error which I will try and reproduce again tomorrow.
Meanwhile, does anyone have any thoughts on what it may be?
30 Dec 2025 14:24 #340713 by Crusader2050
Replied by Crusader2050 on topic Following errors
was this ever resolved? one of the youtubers I watch is currently having a similar problem with a different make of mill but with the same "following" error..
  • Moderator
  • Moderator
30 Dec 2025 14:31 #340714 by tommylight
You mean RotarySMP ?
30 Dec 2025 14:51 #340717 by rodw
Replied by rodw on topic Following errors
Yes its resolved but its a process, not a simple switch. My video shows  best practice for PREEMPT_RT tuning which should resolve following errors.
  • Moderator
  • Moderator
30 Dec 2025 15:34 #340721 by tommylight
Rod,
Analog drives with following errors on some axis/joints, so why are you pushing your video that will not help?
How is your software solution going to help for hardware issues???
30 Dec 2025 16:18 #340723 by rodw
Sorry, I misunderstoeod the issue. Tuning the PREEMPT_RT kernel to minimize latency can solve some following errors and it is not documented anywhere in one place and those who follow my guide have had some impressive results as shown in user comments in the video.
This was a very hard topic to put together in a coherent manner.
Time to create page: 0.107 seconds
