Python Component - $PATH
  • zz912
  • zz912's Avatar Topic Author
  • Platinum Member
  • Platinum Member
05 Jul 2023 16:50 #274839 by zz912
Python Component - $PATH was created by zz912
Hello,
what is $PATH ???
make it executable (chmod +x), and place it on your $PATH
linuxcnc.org/docs/2.9/html/hal/halmodule.html
I am trying to make a python component according to the instructions. It's not working, any idea why?
jarda@CNC:~/linuxcnc/linuxcnc-2.9/configs/sim/gmoccapy/python$ ls
passthrough  remap.py  stdglue.py  toplevel.py
jarda@CNC:~/linuxcnc/linuxcnc-2.9/configs/sim/gmoccapy/python$ halrun
halcmd: loadusr passthrough
<stdin>:1: execv(passthrough): No such file or directory
halcmd:
05 Jul 2023 17:22 - 05 Jul 2023 17:30 #274840 by JPL
Replied by JPL on topic Python Component - $PATH
echo $PATH
Have a look here too:
opensource.com/article/17/6/set-path-linux
Last edit: 05 Jul 2023 17:30 by JPL.
The following user(s) said Thank You: zz912
  • zz912
  • Platinum Member
  • Platinum Member
05 Jul 2023 17:39 #274841 by zz912
Replied by zz912 on topic Python Component - $PATH
Thank you, it works for me now.
05 Jul 2023 17:50 #274842 by MaHa
Replied by MaHa on topic Python Component - $PATH
I use the more comfortable way, keep the component within /home/user/...  environment. Also good for backup of the configuration. In storage folder of component open terminal here, then:
sudo halcompile --install --userspace yourcomponent.py
  • zz912
  • Platinum Member
  • Platinum Member
07 Jul 2023 17:32 #274943 by zz912
To MaHa:
I tried your way, but it did not work.
jarda@CNC:~/Plocha$ halcompile --install --userspace passthrough.py
jarda@CNC:~/Plocha$ halrun
halcmd: Traceback (most recent call last):
  File "/home/jarda/linuxcnc/linuxcnc-2.9/bin/passthrough", line 2, in <module>
    h = hal.component("passthrough")
NameError: name 'hal' is not defined
I cannot use "sudo", because I have RIP instalation.
07 Jul 2023 23:39 #274979 by MaHa
All info about is here and this worked for me:
linuxcnc.org/docs/stable/html/man/man1/halcompile.1.html
without root it might be difficult, but i don't know, as i have installed from .iso.
07 Jul 2023 23:52 #274981 by tommylight
Replied by tommylight on topic Python Component - $PATH
Did you set the RIP environment before running those commands?
Just a stab in the dark as i have not used RIP for over 5 years or more.
  • zz912
  • Platinum Member
  • Platinum Member
08 Jul 2023 04:45 - 08 Jul 2023 05:09 #274990 by zz912
If I didn't use rip-environment, halrun wouldn't work.
I also didn't write that I use Debian Bookworm.
Last edit: 08 Jul 2023 05:09 by zz912.
  • zz912
  • Platinum Member
  • Platinum Member
23 Jul 2023 16:41 #276086 by zz912
I tested it in:
Debian GNU/Linux 10 (buster)  LCNC 2.8
Debian GNU/Linux 10 (buster)  LCNC 2.9
same error as here:
forum.linuxcnc.org/38-general-linuxcnc-q...omponent-path#274943
zdenek@CNC:~/linuxcnc/linuxcnc-2.9$ halcompile --install --userspace passthrough.py
zdenek@CNC:~/linuxcnc/linuxcnc-2.9$ halrun
  File "/home/zdenek/linuxcnc/linuxcnc-2.9/bin/passthrough", line 2, in <module>
Note: Using POSIX realtime
zdenek@CNC:~/linuxcnc/linuxcnc-2.9$ sudo halcompile --install --userspace passthrough.py
[sudo] heslo pro zdenek:
sudo: halcompile: příkaz nenalezen
zdenek@CNC:~/linuxcnc/linuxcnc-2.8.4$ source scripts/rip-environment
zdenek@CNC:~/linuxcnc/linuxcnc-2.8.4$ halcompile --install --userspace passthrough.py
zdenek@CNC:~/linuxcnc/linuxcnc-2.8.4$ halrun
  File "/home/zdenek/linuxcnc/linuxcnc-2.8.4/bin/passthrough", line 2, in <module>
23 Jul 2023 21:00 #276110 by cmorley
Replied by cmorley on topic Python Component - $PATH
can you post the file for passthrough?
Time to create page: 0.571 seconds
