Python Component - $PATH
  • zz912
  • zz912's Avatar Topic Author
  • Platinum Member
  • Platinum Member
24 Jul 2023 03:22 #276122 by zz912
Replied by zz912 on topic Python Component - $PATH
Here:
File Name: passthrough.py
File Size:0 KB
24 Jul 2023 03:31 #276123 by cmorley
Replied by cmorley on topic Python Component - $PATH
You posted the error message  (note line 2):
halcmd: Traceback (most recent call last):
  File "/home/zdenek/linuxcnc/linuxcnc-2.8.4/bin/passthrough", line 2, in <module>
    h = hal.component("passthrough")
NameError: name 'hal' is not defined
But the file you posted line 2 is different:
1 #!/usr/bin/env python3
2 import hal, time
3 h = hal.component("passthrough")
4 h.newpin("in", hal.HAL_FLOAT, hal.HAL_IN)
5 h.newpin("out", hal.HAL_FLOAT, hal.HAL_OUT)
6 h.ready()
7 try:
8    while 1:
9       time.sleep(1)
10       h['out'] = h['in']
11 except KeyboardInterrupt:
12   raise SystemExit
You might not be running the file you think you are.
The following user(s) said Thank You: zz912
24 Jul 2023 03:34 #276124 by cmorley
Also I don't think 2.8 can run python3 code
  • zz912
  • Platinum Member
  • Platinum Member
24 Jul 2023 04:39 #276125 by zz912
Because, this is not halcompiled file.I will find the halcompiled file and send it tonight.
  • zz912
  • Platinum Member
  • Platinum Member
25 Jul 2023 02:44 #276196 by zz912
/home/zdenek/linuxcnc/linuxcnc-2.9/bin/passthrough :
#!/usr/bin/python3.7
h.ready()
try:
    while 1:
        time.sleep(1)
        h['out'] = h['in']
    raise SystemExit
halcompile stole "import hal, time".
Why?
25 Jul 2023 03:48 #276199 by phillc54
Replied by phillc54 on topic Python Component - $PATH
Try adding a blank line immediately before the import line in passthrough.py
  • zz912
  • Platinum Member
  • Platinum Member
25 Jul 2023 13:18 #276223 by zz912
It helped. It works. Thank you.
/home/zdenek/linuxcnc/linuxcnc-2.9/passthrough.py
import hal, time
h.ready()
try:
    while 1:
        time.sleep(1)
        h['out'] = h['in']
    raise SystemExit
import hal, time
h.ready()
try:
    while 1:
        time.sleep(1)
        h['out'] = h['in']
    raise SystemExit
Is this a bug?
This example is here:
linuxcnc.org/docs/2.9/html/hal/halmodule..._basic_usage_example
25 Jul 2023 23:41 #276274 by phillc54
Yes, it is a bug. A fix has been pushed to 2.9.
  • zz912
  • Platinum Member
  • Platinum Member
26 Jul 2023 16:35 #276314 by zz912
I tested your fix:
github.com/LinuxCNC/linuxcnc/pull/2597
It works. Good job.
Time to create page: 0.260 seconds
