Mesa 6i24-25 - recover
- informer
12 Jul 2023 12:03 - 12 Jul 2023 12:10 #275280
by informer
Mesa 6i24-25 - recover was created by informer
Hi guys,I have a question regarding the Mesa Anything i/o 6i24-25. I flashed the card with a .bit-file with mesaflash. By the way it was a .bit- file from hostmod2. The flash was successful. Now the yellow LED (/INIT) and the red LED (/DONE) is on permanently. Since then I can't find my card on the PCI bus. Has anyone had experience with this?
Last edit: 12 Jul 2023 12:10 by informer.
- Thank you received: 5330
12 Jul 2023 12:41 - 12 Jul 2023 12:41 #275281
Replied by PCW on topic Mesa 6i24-25 - recover
What bitfile did you write to the 6I24?
It should have a name like 5i24_25_xxxxx.bit
You should be able to recover with
sudo mesaflash --device 6i24 --recover --write 5i24_25_justio.bit
Last edit: 12 Jul 2023 12:41 by PCW.
- informer
12 Jul 2023 12:59 #275282
by informer
Replied by informer on topic Mesa 6i24-25 - recover
Thank you very much for your answer. I have flashed the bitfile "5i24_25_svss6_8.bit".
I also wanted to try the "--recover option", however I can't find my Mesa card on the PCI bus anymore.
Before flash, lspci gave me the following:
01:00.0 PCI bridge: Texas Instruments XIO2001 PCI Express-to-PCI Bridge
02:00.0 DPIO module: Device 2718:5124 (rev 01)
After flashing, lspci gave me the following output:
Even with mesaflash I can't find my card anymore.
12 Jul 2023 13:50 #275283
The recover option does not need the card PCI id (which requires a valid FPGA configuration) just the XIO2001
Does
succeed?
Does
succeed?
- informer
12 Jul 2023 14:14 #275284
by informer
The command "sudo mesaflash --device 6i24 --recover --write 5i24_25_justio.bit" gives me:
No 6I24 board found
No 6I24 board found
12 Jul 2023 14:27 #275285
Try this
sudo mesaflash --device 6i25 --recover --write 5i24_25_justio.bit
- informer
13 Jul 2023 06:14 #275317
by informer
I've now tried various possibilities, but the board can no longer be found.
sudo mesaflash --device 5i24 --recover --write 5i24_25_justio.bit
-> No 5I24 board found
-> No 6I24 board found
-> No 6I25 board found
Are there other possibilities to reset the board? Thanks for your help.
13 Jul 2023 14:41 #275344
What Mesaflash version do you have?
Is the XIO2001 bridge still visible in lspci?
You might try updating to the latest and if that doesn't work, I will try and duplicate the issue here.
- informer
14 Jul 2023 11:54 #275406
by informer
I have the version:
Mesaflash version 3.4.7
I mean this is already the latest version.
The XIO2001 bridge is still visible in lspci
14 Jul 2023 13:38 #275415
Try mesaflash version 3.3.
I think the new name munging in 3.4+ broke the recover feature
I will fix 3.4, but its a bit tricky
Time to create page: 0.132 seconds
