Problems with including comp userspace application file to LinuxCNC project
25 Aug 2023 16:07 #278936 by Aciera
Maybe this is the case because I have took linuxcnc install CD iso file.
Yes that would explain it.
I guess you could try to purge linuxcnc from the system and then go through the rip installation again.
Is there a compelling reason for using version 2.8?
If not then I would try a debian Bookworm installation and do a rip installation of linuxcnc from github _without_ installing the 'linuxcnc' package from the package manager.
25 Aug 2023 21:14 #278956 by smal
Why would you take a debian bookworm installation instead of linuxcnc iso instalation? Can you go more into depth with explanation.
26 Aug 2023 05:33 #278990 by Aciera
Because a LinuxCNC ISO will have linuxcnc already installed as a deb.
From what I understand you are trying to work on the source code and for that you need a rip installation. If I got that wrong and you only want to work on components and thus only need halcompile then you don't need the full source and thus you don't need a rip install then a linuxcnc iso should be fine. Although you will need the 'linuxcnc-dev' package.
26 Aug 2023 08:35 #279000 by smal
I started with LinuxCNC ISO. Because there was no source code I downloaded it from git repository and yes I need that because I was forced to change halui.cc file to make some of my comp file work as expected.
If I understand you correctly there can be problems with this approach because the links to different software parts are not consistent any more?
The solution for that would be to take a fresh official debian installation and get the LinuxCNC from the github then make -> sudo make setuid. If I understand you correctly this is called a rip installation?
Regarding downloading official LinuxCNC packages there are several possibilities. I can proceed with master or take 2.8 or 2.9. Which would you recommend to work with, I mean, it will work fine without further tweaking?
Just for my knowledge: how to purge the LinuxCNC from the system? Do you delete with that whole software package together with links?
26 Aug 2023 09:07 - 26 Aug 2023 09:11 #279002 by Aciera
Yes
Yes
If you are fine with using python3/gtk3 then proceed with 2.9 if you don't need the absolute bleeding edge of development.
[edit] Since you don't want to install 'packages' with a rip installation '2.9'/'master' here refers to the github branch.[/edit]
What I meant is that you could try to get rid of the deb installation using:
$ sudo apt purge linuxcnc
and/or
$ sudo apt purg linuxcnc-dev
But really, instead of fiddling with the mess you might just as well give yourself a clean rip installation using bookworm. Which will require the installation of the needed dependencies for linuxcnc, of course.
[/quote]
Last edit: 26 Aug 2023 09:11 by Aciera.
26 Aug 2023 19:35 #279022 by smal
I am now in the process of setting things up for linuxcnc on Debian 12.1 Bookworm.
I have made a fresh installation on a new harddisk and downloaded linuxcnc 2.9 from the github. Now I would like to make a compile of the software package, but some things are missing. Bussiness as usual.
So far I was able to install following software:
sudo apt-get install automake
apt install build-essential
sudo apt-get install pkg-config
sudo apt-get install libudev-dev
sudo apt-get install libmodbus-dev
sudo apt-get install libusb-1.0-0-dev
sudo apt-get install libglib2.0-dev
sudo apt-get install libgtk2.0-dev
sudo apt install libgtk-3-dev
sudo apt-get update -y
sudo apt-get install -y yapps2
apt-get install intltool
sudo apt-get install libboost-all-dev
sudo apt-get install tcl-lib
sudo apt-get update
sudo apt-get install tcl tcllib
apt-get install tk
apt-get install python-tk
sudo apt install python3-tk
But when I run ./configure --with-realtime=uspace
I get this error:
checking whether boost_python is the correct library... no
checking whether boost_python311 is the correct library... yes
checking whether to build documentation... no
checking for sys/io.h... yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking for semtimedop... yes
checking for optreset... no
checking for library containing dlopen... none required
checking for library containing clock_nanosleep... none required
checking for tcl... tclConfig.sh not found, trying tcl.h and libs.
If it doesn't work try running ./configure --with-tclConfig=<path to tclConfig.sh>
checking for tcl.h... no
checking for library containing Tcl_Init... -ltcl8.6
checking for tk... dirname: missing operand
Try 'dirname --help' for more information.
tkConfig.sh not found, trying tk.h and libs.
If it doesn't work try running ./configure --with-tkConfig=<path to tkConfig.sh>
checking for tk.h... no
checking for library containing Tk_Init... no
configure: error: tk lib not found
What to do to get tk lib installed?
26 Aug 2023 21:41 #279033 by rodw
There are many more dependencies. You can ask the build environment to list them. Then you can copy into a text editor, clean up and paste back into the terminal preceded by sudo apt install.
I did a video which is still current.
The following user(s) said Thank You: smal
27 Aug 2023 14:10 #279091 by smal
Thanks a lot for this video. It helped me a lot to make this compile process work.
Now I am in a position to start the linuxcnc from console and when I do that I get following printouts:
smal@linuxcnc:~/linuxcnc-2.9$ linuxcnc
LINUXCNC - 2.9.0~pre1
Machine configuration directory is '/home/smal/linuxcnc-2.9/configs/sim/axis'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
Note: Using POSIX non-realtime
Found file(lib): /home/smal/linuxcnc-2.9/lib/hallib/core_sim.hal
Found file(lib): /home/smal/linuxcnc-2.9/lib/hallib/sim_spindle_encoder.hal
Found file(lib): /home/smal/linuxcnc-2.9/lib/hallib/axis_manualtoolchange.hal
Found file(lib): /home/smal/linuxcnc-2.9/lib/hallib/simulated_home.hal
Found file(lib): /home/smal/linuxcnc-2.9/lib/hallib/check_xyz_constraints.hal
Found file(REL): ./cooling.hal
File "/home/smal/linuxcnc-2.9/bin/axis", line 24, in <module>
from OpenGL.GL import *
ModuleNotFoundError: No module named 'OpenGL'
link (updating variable file): No such file or directory
task: 75 cycles, min=0.000014, max=0.001701, avg=0.001040, 0 latency excursions (> 10x expected cycle time of 0.001000s)
LinuxCNC terminated with an error. You can find more information in the log:
/home/smal/linuxcnc_debug.txt
and
/home/smal/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
smal@linuxcnc:~/linuxcnc-2.9$ cd src
smal@linuxcnc:~/linuxcnc-2.9/src$ git pull
bash: git: command not found
What is with this OpenGL Module? Does it has to be installed separatelly?
27 Aug 2023 14:18 #279092 by smal
If I understand link concept (dependencies) correctly, than I can have only one LinuxCNC source code package on a system? Let´s say I can not have a working folder linuxcnc-2.9 and an experimental folder linuxcnc-2.9exp on the system because links (dependencies) will not work as expected?
Just to clarify this detail.
27 Aug 2023 15:00 - 27 Aug 2023 15:02 #279093 by Aciera
You can have as many git cloned folders (ie as many rip installations) on your system as you like.
To run one you need to open a terminal, cd to the respective folder and do:
$ source scripts/rip-environment
As for the openGL error, try
$ sudo apt install python3-opengl
[edit]
The problems come from having both 'RIP' and 'package' installs on the same system.
Last edit: 27 Aug 2023 15:02 by Aciera.
Time to create page: 0.200 seconds
