- LinuxCNC
- General LinuxCNC Questions
- Problems with including comp userspace application file to LinuxCNC project
- smal
- Thank you received: 4
27 Aug 2023 17:09 #279098
by smal
Replied by smal on topic Problems with including comp userspace application file to LinuxCNC project
$ sudo apt install python3-opengl helped but now I have some other error:
smal@linuxcnc:~/linuxcnc-2.9$ linuxcnc
LINUXCNC - 2.9.0~pre1
Machine configuration directory is '/home/smal/linuxcnc-2.9/configs/sim/axis'
Machine configuration file is 'axis_mm.ini'
Starting LinuxCNC...
Note: Using POSIX non-realtime
Found file(lib): /home/smal/linuxcnc-2.9/lib/hallib/core_sim.hal
Found file(lib): /home/smal/linuxcnc-2.9/lib/hallib/sim_spindle_encoder.hal
Found file(lib): /home/smal/linuxcnc-2.9/lib/hallib/axis_manualtoolchange.hal
Found file(lib): /home/smal/linuxcnc-2.9/lib/hallib/simulated_home.hal
Found file(REL): ./cooling.hal
link (updating variable file): No such file or directory
No option 'tto_g11' in section: 'DEFAULT'
No option 'show_program' in section: 'DEFAULT'
No option 'show_rapids' in section: 'DEFAULT'
No option 'program_alpha' in section: 'DEFAULT'
No option 'show_live_plot' in section: 'DEFAULT'
No option 'show_tool' in section: 'DEFAULT'
No option 'show_extents' in section: 'DEFAULT'
No option 'show_offsets' in section: 'DEFAULT'
No option 'grid_size' in section: 'DEFAULT'
No option 'show_machine_limits' in section: 'DEFAULT'
No option 'show_machine_speed' in section: 'DEFAULT'
No option 'show_distance_to_go' in section: 'DEFAULT'
No option 'dro_large_font' in section: 'DEFAULT'
No option 'block_delete' in section: 'DEFAULT'
No option 'optional_stop' in section: 'DEFAULT'
note: MAXV max: 53.340 units/sec 3200.400 units/min
note: LJOG max: 53.340 units/sec 3200.400 units/min
note: LJOG default: 30.480 units/sec 1828.800 units/min
note: jog_order='XYZ'
note: jog_invert=set()
File "/home/smal/linuxcnc-2.9/bin/axis", line 3967, in <module>
get_coordinate_font(vars.dro_large_font.get())
File "/home/smal/linuxcnc-2.9/bin/axis", line 3845, in get_coordinate_font
glnav.use_pango_font(coordinate_font, 0, 128)
File "/home/smal/linuxcnc-2.9/lib/python/glnav.py", line 21, in use_pango_font
pango_context = PangoCairo.create_context(context)
KeyError: 'could not find foreign type Context'
task: 1499 cycles, min=0.000013, max=0.001754, avg=0.001057, 0 latency excursions (> 10x expected cycle time of 0.001000s)
LinuxCNC terminated with an error. You can find more information in the log:
/home/smal/linuxcnc_debug.txt
and
/home/smal/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
What to do?
and
What to do?
- Thank you received: 2163
27 Aug 2023 18:17 #279101
Replied by Aciera on topic Problems with including comp userspace application file to LinuxCNC project
Try:
$ sudo apt install python3-gi-cairo
The following user(s) said Thank You: smal
- smal
27 Aug 2023 18:45 #279104
by smal
This works now. I was able to start LinuxCNC. Thank you very much.
- smal
27 Aug 2023 18:50 #279105
by smal
Ok, I would like to make a shortcut on the desktop but this option can not be activated in Linuc CNC Configurator Selector.
Can this somehow be corrected?
- smal
27 Aug 2023 18:56 #279107
by smal
This is also resolved now. I have a shortcut on the desktop without LinuxCNC emblem. How to add that?
- smal
27 Aug 2023 20:12 #279111
by smal
Ok. This problem is also solved.
- Thank you received: 4138
28 Aug 2023 00:11 #279122
Replied by rodw on topic Problems with including comp userspace application file to LinuxCNC project
Great to see you solved it. It is annoying that some dependencies are not listed when you ask for them. Sometimes you will see errors when building that alert you to a missing dependency
- smal
28 Aug 2023 20:22 #279205
by smal
Hello
With a new motherboard+processor+graphic card and old harddisk problems came again to surface:
Found file(lib): /home/smal/linuxcnc-2.9/lib/hallib/check_xyz_constraints.hal
Starting DISPLAY program: axis
task: 1162 cycles, min=0.000009, max=0.001103, avg=0.001046, 0 latency excursions (> 10x expected cycle time of 0.001000s)
Debug file information:
Note: Using POSIX realtime
note: MAXV max: 5.000 units/sec 300.000 units/min
note: LJOG max: 5.000 units/sec 300.000 units/min
note: LJOG default: 0.250 units/sec 15.000 units/min
File "/usr/lib/python3/dist-packages/OpenGL/latebind.py", line 43, in __call__
return self._finalCall( *args, **named )
TypeError: 'NoneType' object is not callable
During handling of the above exception, another exception occurred:
File "/home/smal/linuxcnc-2.9/lib/python/glnav.py", line 65, in use_pango_font
glBitmap(1, 0, 0, 0, 0, h-d, bytearray([0]*4))
File "/usr/lib/python3/dist-packages/OpenGL/latebind.py", line 47, in __call__
File "/usr/lib/python3/dist-packages/OpenGL/wrapper.py", line 700, in wrapperCall
raise err
File "/usr/lib/python3/dist-packages/OpenGL/wrapper.py", line 693, in wrapperCall
result = wrappedOperation( *cArguments )
File "/usr/lib/python3/dist-packages/OpenGL/platform/baseplatform.py", line 415, in __call__
return self( *args, **named )
File "/usr/lib/python3/dist-packages/OpenGL/error.py", line 230, in glCheckError
raise self._errorClass(
OpenGL.error.GLError: GLError(
err = 1285,
description = b'out of memory',
baseOperation = glBitmap,
pyArgs = (
1,
0,
0,
0,
0,
16.0,
<OpenGL.arrays._buffers.Py_buffer object at 0x7fe90be43d10>,
cArgs = (
1,
0,
0,
0,
0,
16.0,
cArguments = (
1,
0,
0,
0,
0,
16.0,
3104
3161
Stopping realtime threads
Unloading hal components
Any idea what to do?
Or is a new OS install needed with everything else when motherboard + processor changed?
raise err
err = 1285,
pyArgs = (
1,
0,
0,
0,
0,
16.0,
cArgs = (
1,
0,
0,
0,
0,
16.0,
cArguments = (
1,
0,
0,
0,
0,
16.0,
3104
3161
29 Aug 2023 06:39 #279261
Maybe pull the graphics card, and try again using the on board graphics.
- smal
29 Aug 2023 19:47 #279309
by smal
I do not have such possibility. because the processor does not support on board graphics.
- LinuxCNC
Time to create page: 0.239 seconds
