- Thank you received: 2349
I could be wrong, but given the current API that linuxcnc is written on top of, this would likely require very deep work into the core of linuxcnc. AFAICT there are no tools in the API that can synchronize the threads for instance. Also the code appears to be heavily written for serial execution. What would probably need to happen otomh is that the api would need a way to have each thread run independently with a centrally controlled memory management cache to synchronize the various threads. so you would have a trajectory planner " all required code to execute motion" for each new instance of a aixs and have it run in it's own thread and then a central trajectory planner would keep the various thread in sync.Aciera post=313997 userid=25994Hm, as I understand it, this does _not_ give us multi thread gcode execution as that would require multiple parallel motion planners in the same linuxcnc instance. A single instance of linuxcnc cannot interpolate more than one tool path at the same time.
