Trajectory Planner using Ruckig Lib
1 year 11 months ago - 1 year 11 months ago #314708 by smc.collins
the faster the pulse count, and the smaller the unit of measure, at a fixed frequency, the bigger the problem becomes. I am referring to a edge case but it is something to beware of.
Last edit: 1 year 11 months ago by smc.collins.
1 year 11 months ago #314748 by Grotius
The ethercat auto configurator works finally !!
When program starts, it initializes the ethercat devices by retrieving a digital xml configuration.
For this i poked around in the etherlab source code, and added some function's to retrieve this digital xml information.
From the given digital xml information, it then does some logic and it create's hal pins automaticly.
This is ideal for lazy system integrators. image missing /media/kunena/emoticons/smile.png
For this to use you don't need a .xml config file like in linuxcnc-ethercat.
I also solved a etherlab_master software  bug related to slave alias numbers, wich where not consistent and
resulted in head scratching for some time as the aliases are not printed by : "$ ethercat xml"
The terminal output when starting the program :
Starting EtherCAT master 1.5.2  done init example 0. init ethercat start. Print ethercat devices and retrieve device data vector. No alias given, alias - pdo entry registration:          Name:EL2124 4K. Dig. Ausgang 5V, 20mA          Slave Alias: 0          Position: 1          Vendor ID: 2          Product Code: #x084c3052          PDO Entry Index: #x7000          PDO Entry Subindex: 1          Name:EL2124 4K. Dig. Ausgang 5V, 20mA          Slave Alias: 0          Position: 2          Vendor ID: 2          Product Code: #x084c3052          PDO Entry Index: #x7000          PDO Entry Subindex: 1          Name:EL2124 4K. Dig. Ausgang 5V, 20mA          Slave Alias: 0          Position: 3          Vendor ID: 2          Product Code: #x084c3052          PDO Entry Index: #x7000          PDO Entry Subindex: 1          Name:EL1004 4K. Dig. Eingang 24V, 3ms          Slave Alias: 0          Position: 4          Vendor ID: 2          Product Code: #x03ec3052          PDO Entry Index: #x6000          PDO Entry Subindex: 1          Name:EL2794 4K. Dig. Ausgang 24V AC/DC, 2A, kurzschlussfest          Slave Alias: 0          Position: 5          Vendor ID: 2          Product Code: #x0aea3052          PDO Entry Index: #x7000          PDO Entry Subindex: 1          Name:EL2808 8K. Dig. Ausgang 24V, 0.5A          Slave Alias: 0          Position: 6          Vendor ID: 2          Product Code: #x0af83052          PDO Entry Index: #x7000          PDO Entry Subindex: 1          Name:EL3162 2K. Ana. Eingang 0-10V          Slave Alias: 0          Position: 7          Vendor ID: 2          Product Code: #x0c5a3052          PDO Entry Index: #x3101          PDO Entry Subindex: 1          Name:EL3162 2K. Ana. Eingang 0-10V          Slave Alias: 0          Position: 7          Vendor ID: 2          Product Code: #x0c5a3052          PDO Entry Index: #x3101          PDO Entry Subindex: 2          Name:EL3162 2K. Ana. Eingang 0-10V          Slave Alias: 0          Position: 7          Vendor ID: 2          Product Code: #x0c5a3052          PDO Entry Index: #x3102          PDO Entry Subindex: 1          Name:EL3162 2K. Ana. Eingang 0-10V          Slave Alias: 0          Position: 7          Vendor ID: 2          Product Code: #x0c5a3052          PDO Entry Index: #x3102          PDO Entry Subindex: 2          Name: empty          Slave Alias: 0          Position: 0          Vendor ID: 0          Product Code: #x00000000          PDO Entry Index: #x0000          PDO Entry Subindex: 0 halpin names:          EL2124_1_0_0_IN_BOOL          EL2124_1_1_0_IN_BOOL          EL2124_1_2_0_IN_BOOL          EL2124_1_3_0_IN_BOOL          EL2124_2_0_0_IN_BOOL          EL2124_2_1_0_IN_BOOL          EL2124_2_2_0_IN_BOOL          EL2124_2_3_0_IN_BOOL          EL2124_3_0_0_IN_BOOL          EL2124_3_1_0_IN_BOOL          EL2124_3_2_0_IN_BOOL          EL2124_3_3_0_IN_BOOL          EL1004_4_0_0_OUT_BOOL          EL1004_4_1_0_OUT_BOOL          EL1004_4_2_0_OUT_BOOL          EL1004_4_3_0_OUT_BOOL          EL2794_5_0_0_IN_BOOL          EL2794_5_1_0_IN_BOOL          EL2794_5_2_0_IN_BOOL          EL2794_5_3_0_IN_BOOL          EL2808_6_0_0_IN_BOOL          EL2808_6_1_0_IN_BOOL          EL2808_6_2_0_IN_BOOL          EL2808_6_3_0_IN_BOOL          EL2808_6_4_0_IN_BOOL          EL2808_6_5_0_IN_BOOL          EL2808_6_6_0_IN_BOOL          EL2808_6_7_0_IN_BOOL          EL3162_7_0_0_OUT_UINT          EL3162_7_0_1_OUT_UINT          EL3162_7_1_0_OUT_UINT          EL3162_7_1_1_OUT_UINT PDO entry registration ok. Master ok. domain1_pd ok. init ethercat succes.
So far 4 data types are integrated : bool, uint, string, bit.
It currently looks at one master. But code may look at more masters in the future.
So far so good !
Integration in linuxcnc is not that difficult, as you can add this code into a component, using a function like
rtapi_app_main(); will then run the code, will also create hal pin's etc. with some slightly modifications.
The following user(s) said Thank You: endian, tiagounderground, Darium
1 year 10 months ago #315795 by Grotius
Did some work on the super imposed interpreter code again.
It's now able to do more things like : stop, restart at line, set variable at runtime.
The video show's basic functionality. And show how sub interpreters may run their own program.
There is a machine-consume button, wich simulates the motion planner takes lines of gcode from the interpreter output buffer.
The delay input's slow's down the simulation wich enables us to view the step's the interpreter does.
Have to make the qt layout more fancy.
The following user(s) said Thank You: yrsiddhapura, wellingtoncsouza, endian, Darium, smc.collins, anton610, Unlogic
1 year 10 months ago #315957 by smc.collins
that is awesome, for some reason multi spindle swiss machine just popped into my head looking at that. I have been watching to many Tornos videos drooling lol
1 year 10 months ago #316008 by Grotius
Thank you Collins.
Attached video shows the 3 interpreters tools moving around.
There is no motion component or whatever. The tool is just jumping to the consumed gcode position.
One of the problem's is when adding gcode segments to a infinite program, it has to check for duplicates,
and there must be a limit to the gcode preview. Otherwise we get a buffer overflow.
This run's quite stable, fixed some runtime bug's.
The following user(s) said Thank You: tommylight, meister, Lcvette, wellingtoncsouza, smc.collins
1 year 10 months ago - 1 year 10 months ago #316019 by smc.collins
that's cool
Last edit: 1 year 10 months ago by smc.collins.
The following user(s) said Thank You: Lcvette, Grotius
Time to create page: 0.244 seconds
