Trajectory Planner using Ruckig Lib
1 year 10 months ago #316046 by Grotius
Hi Collins,
Today was a good day for coding. This morning still had a crash problem for the interpreter.
For the colors of the code i thought, RGB, red, green, blue.
Now the super imposed interpreter is running ok.
Added the realtime environment : base-thread & servo thread is loaded and running.
The servo-thread has now 3 motion components running. This is really cool.
libmotion_0.so -> produces motion for main interpreter (red)
libmotion_1.so -> produces motion for sub_0 interpreter (green)
libmotion_2.so -> produces motion for sub_1 interpreter (blue)
The idea is then to send the interpreter's gcode output to the motion components over the 1ms thread.
We do this over shared_memory.
Then we have to code the motion components. They will use the scurve and toolpath optimalisation as seen before.
The base thread has the libethercat.so component running soon. image missing /media/kunena/emoticons/smile.png  This has ethercat auto configuration.
This is going to be a cool winter project.
There are a few questions, like what if sub_0 interpreter is a tool changer. The green tool cone is then not valid.
Depending on the machine configuration, the green and or blue cone must be replaced by something else?
codeberg.org/skynet/realtime_app/src/branch/master
The following user(s) said Thank You: Lcvette, wellingtoncsouza, endian, smc.collins
1 year 10 months ago #316058 by smc.collins
when this is done, this will be a huge optorunity for linuxcnc , how much of this code should be upstreamed to linuxcnc ?
1 year 10 months ago #316060 by Grotius
Hi Collins,
It's far from linuxcnc compatible.
The hal works different and the rtapi works different.
The code is entirely different. The realtime approach is the same.
The following user(s) said Thank You: tommylight, Lcvette
1 year 10 months ago #316095 by Lcvette
so is this going to be a linuxcnc alternative cnc controller?
1 year 10 months ago #316179 by Grotius
Hi Lcvette,
It's indeed a alternative controller, once it finished.
This can take a long time. Some are good coding day's, some are bad coding day's without good progress.
It turned out, modifying lcnc's code to do thing's i would see accomplished is almost impossible.
Best reason is entanglement.
Then just writing new code from scratch is 10x faster to get things done.
There are no goals for me. It's just a project to try out new things wich got my interest's.
It's not the purpose to outsmart lcnc or something like that. Or claiming thing are better etc.
Altrough it is interesting to find out differences in lcnc and this approach.
Like this has bi-directional hal pins and used modern boost interprocess for shared memory.
Today did a mayor bug fix. It turn's out that multiple shared memory regions updated by thread's, would not exchange data
properly. Even when mutex etc. was set.
In the end it worked by using a single shared memory region for all thread's.
The following user(s) said Thank You: tommylight, Clive S, Lcvette
1 year 10 months ago #316203 by robh
sorry not been here for awhile but life just got in the way, very bussy months here
looks like you have been bussy Grotius
dont forget with multi program running like i showed, its important that you dont tie each "interperter locekd to an axis group" becasue it needs to be far from it to be powerfull, any instanact should read any spindle feedback, know where other axis are so can follow them as a slave or master axis "offset" etc
so yes that a hal layer thing so hal can pass info between each other.
because each program group can and should be able to command other axis out side its "group" so program 2, shuld be able to move Z1 , so part can position from the guide bush. very much how you manage mode/group switching
ill try and find the page in one of my manuals for lathe and share will give you some ideas i think. better than many words, but abit like this...
while on swiss yes each "program instance" has an axis group set. i can change mode with a G code, like G710 etc (there are loads of these code sets) and it will control how these 3 programs interact together, you have to use same G710 setting code in all 3 or it alarms out
then control knows program 2 is now master , or program 3 is master etc realy which axis group the other 2 must be salved too..
(btw not all swiss etc have 3 heads, some only have 2, some have just 1)
eg
that way, you can program threading on program 1 , have X and Z do thread of a pitch say 1mm, while program 2 can also do threading, following Z in the program of Z1 but do a different pitch on Z2 of say 2mm , as it can read the spindle encoder also into both interpreters etc..,
on a fixed head lathe, you dont need to follow Z1 as your stock does not move,
unless your chasing the main turret with a sub spindle, while main turet works on front spindle like that miyano video.
yes you can bring in a sub for support and hold the part, and have Z3 follow Z1 while turret does what ever.. sounds complex but with simple switching etc becomes abit natral thinking on program layout etc for the siwss world of coding and setup.
but yes as you said making linuxcnc multi interpreter and multi hal is abig challenge many have looked at it before and no one has ever taken it on.
sorry for long reply
Time to create page: 0.802 seconds
