Trajectory Planner using Ruckig Lib
2 years 11 months ago #285001 by Grotius
Hi Joco,
Thanks for your detailled error report.
The gcode file is from cam repository : github.com/grotius-cnc/cam/blob/main/gcode.ngc
I added your modified gcode_test_jw.ngc to the source. And opened the file in axis. Then press run after home,
and error reproduced indeed.
tpAddCircle.
vector size: 6
lengt of this segment: -nan
traject lenght now: -nan
arc startpoint x: 192.000000, y: 162.000000, z: -1.500000
arc endpoint x: 192.000000, y: 162.000000, z: -1.500000
arc center x: 164.000200, y: 162.000000, z: -1.500000
It's obvious, the arc has the same start- & endpoint, wich results in a isnan output for arc lenght in this case.
So i can do 2 things here.
  1. Change it into a line when start & end are the same.
  2. Filter out this segment, trow it away
The following user(s) said Thank You: akb1212
2 years 11 months ago #285002 by Joco
So line 21 is:   G03 X192.0000 Y162.0000 I-27.9998 J0.0000 F#<xy_feed>
This essentially a circle.  Use ncviewer.com/ to step through the code file.  Really useful to visualise what is happening where.
Are you factoring the fact the fact that the arc at this line is in fact a circle or is something happening under the hood which is causing this to happen as a result of what is being produced by the ruckig library?
Cheers - J
2 years 11 months ago #285003 by Grotius
The isnan is fixed by changing isnan to 0 output. So segment's are just there, segment lenght is set to zero.
To inform you where in the source this is done :
github.com/grotius-cnc/linuxcnc/blob/884.../tp/tp_lines.cpp#L89
github.com/grotius-cnc/linuxcnc/blob/884.../tp/tp_arcs.cpp#L233
Github is updated.
Joco, it seems the rapids are below the workpiece. But the file run's oke now.
You may edit the file yourself on github.
2 years 11 months ago - 2 years 11 months ago #285004 by Joco
Thanks - yeah its a hack as I can't set WCS to be able to have positive upward Z moves.
Normally Z would be removed on my plasma as that is all under plasmac control.  Once WCS can be set then will change.  OR is it ok to kill off Z moves entirley?  For the purposes of this test file.
J.
Last edit: 2 years 11 months ago by Joco.
2 years 11 months ago #285005 by Grotius
@Joco,
This zero lenght arc is produced by a cam program using cavaliercontours. Normally this would be filtered out by a function, but for no reason it's still there. It has nothing to do with our code and or ruckig lib.
2 years 11 months ago #285006 by Joco
Tested these latest adjustments: #884ce9
No apparent errors but motion on the physical machine is not happen as epected.  It seems to rapid to that "zero arc" point which is supposed to be a hole and just stops.
File Name: axis-scurv...ov24.txt
File Size:255 KB
Time to create page: 0.220 seconds
