Why is this happening?
- gardenweazel
- Thank you received: 10
07 Oct 2023 09:47 #282501
by gardenweazel
Replied by gardenweazel on topic Why is this happening?
Attaching INI and HAL files.
- gardenweazel
07 Oct 2023 09:59 #282502
by gardenweazel
The machine is a BeeLink Mini S
Attaching a copy of the dmesg output.
I've not had many problems if any regarding the DISPLAY. It's important to note that a small window shows momentarily in the bottom
right hand corner of the screen for perhaps 2 seconds and then closes.
Here's some additional detail on the hardware:
andy@file03:~$ sudo lshw -short
H/W path Device Class Description
system MINI S (Default string)
/0 bus MINI S
/0/0 memory 64KiB BIOS
/0/3a memory 8GiB System Memory
/0/3a/0 memory [empty]
/0/3a/1 memory 8GiB SODIMM DDR4 Synchronous 2667 MHz (0.4 ns)
/0/43 memory 256KiB L1 cache
/0/44 memory 6MiB L2 cache
/0/45 memory 4MiB L3 cache
/0/46 processor Intel(R) Celeron(R) N5095A @ 2.00GHz
/0/100 bridge Intel Corporation
/0/100/2 /dev/fb0 display JasperLake [UHD Graphics]
/0/100/4 generic Dynamic Tuning service
/0/100/14 bus Intel Corporation
/0/100/14/0 usb1 bus xHCI Host Controller
/0/100/14/0/1 input USB Receiver
/0/100/14/0/1/0 input28 input Logitech M505/B605
/0/100/14/0/2 input USB Receiver
/0/100/14/0/2/0 input29 input Logitech K400
/0/100/14/0/6 card0 multimedia KTMicro KT USB Audio
/0/100/14/0/8 communication Bluetooth wireless interface
/0/100/14/1 usb2 bus xHCI Host Controller
/0/100/14.2 memory RAM memory
/0/100/15 bus Serial IO I2C Host Controller
/0/100/15.1 bus Serial IO I2C Host Controller
/0/100/15.2 bus Intel Corporation
/0/100/15.3 bus Intel Corporation
/0/100/16 communication Management Engine Interface
/0/100/17 scsi0 storage Intel Corporation
/0/100/17/0.0.0 /dev/sda disk 256GB 256GB SSD
/0/100/17/0.0.0/1 volume 511MiB Windows FAT volume
/0/100/17/0.0.0/2 /dev/sda2 volume 488MiB EFI partition
/0/100/17/0.0.0/3 /dev/sda3 volume 237GiB LVM Physical Volume
/0/100/19 bus Intel Corporation
/0/100/19.1 bus Intel Corporation
/0/100/1c bridge Intel Corporation
/0/100/1c/0 wlp1s0 network Wireless 3165
/0/100/1c.5 bridge Intel Corporation
/0/100/1c.5/0 enp2s0 network RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
/0/100/1e communication Intel Corporation
/0/100/1e.3 bus Intel Corporation
/0/100/1f bridge Intel Corporation
/0/100/1f/0 system PnP device PNP0c02
/0/100/1f/1 system PnP device PNP0c02
/0/100/1f/2 generic PnP device INT3f0d
/0/100/1f/3 system PnP device PNP0c02
/0/100/1f/4 system PnP device PNP0c02
/0/100/1f/5 system PnP device PNP0c02
/0/100/1f/6 system PnP device PNP0c02
/0/100/1f.3 card1 multimedia Jasper Lake HD Audio
/0/100/1f.3/0 input19 input HDA Intel PCH HDMI/DP,pcm=3
/0/100/1f.3/1 input20 input HDA Intel PCH HDMI/DP,pcm=7
/0/100/1f.3/2 input21 input HDA Intel PCH HDMI/DP,pcm=8
/0/100/1f.3/3 input22 input HDA Intel PCH HDMI/DP,pcm=9
/0/100/1f.4 bus Jasper Lake SMBus
/0/100/1f.5 bus Jasper Lake SPI Controller
/1 power Default string
/2 power Default string
/3 power Default string
/4 input0 input Sleep Button
/5 input1 input Power Button
/6 input18 input Video Bus
/7 input2 input Power Button
/0 bus MINI S
- Thank you received: 5337
07 Oct 2023 10:15 #282504
Replied by PCW on topic Why is this happening?
One clue is that 2.9 does not have the
USRMOT: ERROR: command 30 timeout
emcMotionInit: emcTrajInit failed
errors but
master (2.10) does
(I also had to remove the pyvcp and glade stuff since I don't have all the supporting files)
errors but
master (2.10) does
The following user(s) said Thank You: tjtr33
- gardenweazel
07 Oct 2023 13:00 #282511
by gardenweazel
Here's some additional information from DEBUG:
It appears to be failing on the python call.
note: jog_order='XYZA'
note: jog_invert=set()
python3.11: ../src/mesa/state_tracker/st_texture.c:73: st_texture_create: Assertion `height0 > 0' failed.
/home/andy/linuxcnc_rip/scripts/linuxcnc: line 957: 7912 Aborted $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
+ result=134
+ Cleanup
+ echo 'Shutting down and cleaning up LinuxCNC...'
However when I look for the st_texture.c file it's located in:
Somehow that doesn't seem right. Is python calling a C file?
And why is this being called outside to my RIP environment?
andy@file03:~/linuxcnc_rip$ find ../ -name st_texture.c
../Downloads/mesa/mesa/src/mesa/state_tracker/st_texture.c
+ result=134
+ Cleanup
Time to create page: 0.097 seconds
