Connections probles
24 Oct 2023 14:07 #283706 by tommylight
Replied by tommylight on topic Connections probles
sudo apt update
then try to install.
24 Oct 2023 14:51 #283712 by Aciera
Replied by Aciera on topic Connections probles
Can you reach the internet with that computer at all?
If your computer cannot connect to the internet then you are not going to get anywhere trying to download and install software packages.
25 Oct 2023 06:23 #283769 by alfredmaina
Replied by alfredmaina on topic Connections probles
yes i am connected to the internet.. but still unable to edit connections to change my IPv4 from to 10.10.10.10
That is the main challenge that i have
25 Oct 2023 06:44 #283770 by alfredmaina
Hi tommy. I tried to edit the connections using the "edit connections " option but still did not display more options to do so.
I want to try the second method which is to edit the file/etc/network/interface but i cannot get the location to add the below lines:
auto eth1
iface eth1 inet static
address 192.168.1.1
hardware-irq-coalesce-rx-usecs 0
Where do i get that location to add that line
