Thank you for your responses!
I have ordered a samsung hard drive to install on a intel i3 ir i5 chip. Get it next week, or by the 15th of the month.
Part of the reason for using Mesa is linux sees them right away, and set up is relatively easy.
The part I do not know how to move forward is creating the application in Linux from nothing. I have performed programming in HTML, and some assembler, so slow, but possible for me. Why I asked about where to start. You will have your suggestions.
I understand the machine has gcodes. ASCII commands, also, they may be the same. Need the program, will share. Could be several weeks...
Yes, multiple tools, and yes, probe for calculating the finished thickness.
The air bearings will run; we will have a low pressure switch to be sure the spindle is turned off prior to the air failing or going too low. Built into every machine I have known with air bearings.
I think your comment: "...just labor intensive" is very right.
As previously written, we cannot rely on the manufacturer--they take too long to get back to me for everything so far, and being self-reliant is probably out best alternative for such an old machine, and why I asked for help to begin with.
Thank You!!!
david
