QT Dragon crashes - new installation
- DPKdd
06 Jan 2024 22:15 #290011
by DPKdd
QT Dragon crashes - new installation was created by DPKdd
I have a working setup (QTdragon_hd gui) on a converted 3 axis mill (PM-940V). I am attempting to setup a additiona/new dual boot machine that I can use as a backup and place to test new configurations.
I have a fresh debian 12 install and have installed LinuxCNC from the package manager. The installation seems to be fine and the axis sim works like I expect but any time I load a qt dragon (or qt dragon hd) sim the gui display seems to start like I would expect but most of the screen seems to be frozen. Some functions work (sometimes I can select different tabs). copying the error log seems to be not letting me post, but if there is a good way to attach it, please let me know. In addition to the error log, when I click the exit button I get a notification that python3 has stopped responding and an option to wait or force quit.
Any help is appreciated
- DPKdd
06 Jan 2024 23:58 #290018
by DPKdd
Replied by DPKdd on topic QT Dragon crashes - new installation
report attached. I am suspicious that I am missing python3 packages (not sure why?) but I do not know how to identify what is missing.
Thanks again for the help
- Thank you received: 2173
07 Jan 2024 00:14 #290020
Replied by cmorley on topic QT Dragon crashes - new installation
Can you run from a terminal and post the output?
- DPKdd
07 Jan 2024 00:36 #290022
by DPKdd
Here is the terminal output:
dustin@Debiandual:~$ linuxcnc ~/linuxcnc/configs/sim.qtdragon.qtdragon_xyz/qtdragon_inch.ini
LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7
Machine configuration directory is '/home/dustin/linuxcnc/configs/sim.qtdragon.qtdragon_xyz'
Machine configuration file is 'qtdragon_inch.ini'
Starting LinuxCNC...
Note: Using POSIX non-realtime
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
QSocketNotifier: Can only be used with threads started with QThread
[QTvcp.QTVCP.WIDGETS.STATUS_LABEL][WARNING] lbl_maxv_percent : no option recognised (status_label.py:162)
[QTvcp.QTVCP.WIDGETS.STATUS_LABEL][WARNING] lbl_max_rapid : no option recognised (status_label.py:162)
[QTvcp.QTVCP.WIDGETS.STATUS_LABEL][WARNING] lbl_runtime : no option recognised (status_label.py:162)
ngcgui: make_fileset: [Errno 2] No such file or directory: '/home/dustin/nc_files/ngcgui_lib/slot.ngc'
ngcgui: make_fileset: [Errno 2] No such file or directory: '/home/dustin/nc_files/ngcgui_lib/qpocket.ngc'
- DPKdd
07 Jan 2024 01:16 #290024
by DPKdd
Here is the output when I run the sim/example directly from the interface that launches when i run linuxcnc (instead of the version that is saved to my linuxcnc directory as above). Both examples have the same behavior (i.e. gui freezes and python crashes on exit)
07 Jan 2024 05:02 #290046
I don;t see anything jumping out.
Can you open a terminal and type:
qtvcp test_panel
and see if a panel shows.
qtvcp test_panel
- DPKdd
07 Jan 2024 13:54 #290094
by DPKdd
dustin@Debiandual:~$ qtvcp test_panel
tool_mmap_user(): tool mmap not available
poll(): continuing without tool mmap data
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
The repeated warning would display anytime I hovered over the Dial Range or LED Sound menu selection (not sure if that helps)
Additionally, there was "Terminal" pop up window that displayed:
"terminal program urxvt not available. Try sudo apt install rxvt-unicode-256color"
Obviously i can attempt to install rxvt-unicode-256color but I'm not sure if this is a symptom of additional missing packages or an install issue.
Thanks again for the help.
- DPKdd
07 Jan 2024 13:57 #290096
by DPKdd
I should add that all of the functions in the qtvcp test panel seem to work and python3 does not crash/stop responding on exit like it does when exiting the qt_dragon displays.
- Thank you received: 7462
07 Jan 2024 14:03 #290098
Replied by tommylight on topic QT Dragon crashes - new installation
What Desktop Environment are you using?
GNOME and KDE use Wayland, others use still Xorg, as far as i can recall.
Either way everything is going to Wayland so i am following a bit how LinuxCNC behaves but had no time to actually test anything.
- DPKdd
07 Jan 2024 14:28 #290100
by DPKdd
I am using GNOME.
Time to create page: 0.288 seconds
