5 axis motor parameters
- Duatepe
23 Jan 2024 06:44 - 23 Jan 2024 07:19 #291391
by Duatepe
5 axis motor parameters was created by Duatepe
Hello everyone,
I am building an CNC 5 axis and I load the my .ini and .hal file with an example .ngc file. I started the machine and stop it after that I tried to move axis A to previous position but axises moved different I mean it couldn't reach the right position , one axis move faster and passed the position. I think it is about the some motor parameters I dont know. If it is about parameters , how can I enter these parameters. For example;
Motor Harmonic Drive 4th Axis
Table Diameter: 150 mm
Center Height: 100mm
Center Bore: 30mm
Blacklash: 0
Absolute Tolerance: +-30
Max Torque Output: 50 NM
I have seen these parameter on motor.
My configuration file and .hal attached.
Center Bore: 30mm
Blacklash: 0
Last edit: 23 Jan 2024 07:19 by Duatepe.
- Thank you received: 2163
23 Jan 2024 07:57 #291398
Replied by Aciera on topic 5 axis motor parameters
Sounds like your step_scale is off or you are loosing steps. Have you tried running the gcode at a lower feed rate?
- Duatepe
23 Jan 2024 08:01 #291399
by Duatepe
Replied by Duatepe on topic 5 axis motor parameters
You mean it is about step scale or loosing steps. it is not about motor parameters right? Then I will try my works with this information
- Duatepe
23 Jan 2024 08:19 #291403
by Duatepe
I wil try to explain it with more detail
I started the machine and move and started to handle the workpiece(actually is not there just for observation)
But axis maybe rotate too much I dont know, what ever, I stop the machine and I moved the axis A to starting position but problem started,
rotation and axis Y didnt move good. Didnt match . Y moved too fast as much as remember.
- Thank you received: 7461
23 Jan 2024 08:29 #291405
Replied by tommylight on topic 5 axis motor parameters
Upload pictures of the machine, motors, reduction, drives, etc here on the forum so we know at least what we are talking about.
- Duatepe
23 Jan 2024 08:34 #291406
by Duatepe
Ok I will do it when the machine 4. and 5. axises ready. Now 3 axies in usage after a few hours later I hope will be okay but until that time I will send the current machine picture and motor inside.
- Duatepe
23 Jan 2024 08:47 #291408
by Duatepe
Machine Pictures atttached
- Duatepe
23 Jan 2024 08:50 - 23 Jan 2024 08:53 #291409
by Duatepe
Machine Pictures Attached
Last edit: 23 Jan 2024 08:53 by Duatepe.
- Duatepe
23 Jan 2024 08:59 #291411
by Duatepe
As you see, last motor includes 4th 5th axis is there for demo now. Machine is not ready for video yet. Also I can send the video later. .ini and .hal file attached.
23 Jan 2024 09:31 #291413
You have not provided any information about the motor amplifiers, What type are they and are they the original drives that came with the rotary assembly?
Time to create page: 0.161 seconds
