Latency, error finishing read, and IRQ affinity
- Swag
- Thank you received: 3
12 May 2024 16:20 #300450
by Swag
Replied by Swag on topic Latency, error finishing read, and IRQ affinity
I thought I had, I edited the section with the IP address to my card IP address of 10.10.10.11. Obviously I’ve made a mistake, I’ll go back through it again to see.
- Thank you received: 5312
12 May 2024 16:29 #300452
Replied by PCW on topic Latency, error finishing read, and IRQ affinity
Yeah, A bit of error/status reporting would improve that script
- Swag
12 May 2024 16:39 #300456
by Swag
I think I see my mistake, I only changed the second instance (line 145) to 10.10.10.11 and overlooked line 117. Sorry for the trouble and thanks for the help!
I knew it was something I had missed. Odd that the old debian 10 vanilla install just worked, but the debian 12 was so finicky about having the cpu isolated and irq pinned.
12 May 2024 16:54 #300458
Yes, I think some kernel change made Ethernet latency more sensitive to IRQ pinning
- Swag
12 May 2024 18:17 #300464
by Swag
If I rerun rt_setup.sh, it is not updating the two files in /etc/linuxcnc and manually editing the lcnc_setirqaffinities.sh to have the correct IP does not result in the IRQ being pinned to the correct CPU (2 instead of 8, still). So looks like I still have some investigations to do, but at least I now know what needs to be accomplished.
The following user(s) said Thank You: DHeineck
- BryceJ
30 May 2024 02:23 #301800
by BryceJ
Replied by BryceJ on topic Latency, error finishing read, and IRQ affinity
Thanks for the script! Had been fighting this issue for a few days with errors talking to a mesa board on a N100 that I was setting up. Worked great on once I fixed the same issue Swag had. My static IP had been 10.10.10.11. Changed it to 10.10.10.1 and the ping to 10.10.10.10 was good, previously I was getting random 3ms spikes.
ping 10.10.10.10 -i .02
325 packets transmitted, 325 received, 0% packet loss, time 8151ms
rtt min/avg/max/mdev = 0.080/0.101/0.127/0.007 ms
- CNC_Tinkerer
07 Aug 2024 14:27 - 07 Aug 2024 14:33 #307179
by CNC_Tinkerer
Replied by CNC_Tinkerer on topic Latency, error finishing read, and IRQ affinity
Hi!
I am working with a custom ethernet interface and think I really need this IRQ management. Unfortunately I have not been able to get what's described here to work after quite a few hours beating my head on the desk and rereading ALL these posts several times. I've tried a number of things but I don't know much about scripting. I'm probably missing something obvious.
If someone has debugging suggestions or can tell me what other information to post here I would really appreciate it.
The obvious things:
I did install irqbalance via Synaptic. I did change IP to 10.0.0.1 two places in rt_setup.sh--that's the address in interfaces file.
What happens:
If I run rt_setup.sh it says it is creating the affinity file, and it ends up in /etc/linuxcnc as expected with permissions correct. But after restart I seem to end up with ethernet interrupts always on cpu5 where I would expect cpu7.
The script comes up with isolcpus 6,7 in grub, which is what I determined months ago and added manually and seems like it should be correct.
my /etc/network/interfaces (after removing commented out lines and loopback):
Significant things I tried:
Running test script "pinirq_2024-05-12.txt" with parameter enp8s0f0 displays expected results. But watching interrupts stills shows the nic IRQs on cpu5.
I tried using NIC=`enp8s0f0` in place of both awks in rt_setup.sh but that does not work either (note the quotes I used!).
I did have loopback lines and old (commented out) iface and address lines in interfaces file. I removed them and reran everything as I'm not sure how picky that grep is.
section from /proc/interrupts:
Architecture: x86_64
CPU(s): 8
On-line CPU(s) list: 0-7
Thread(s) per core: 2
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: AuthenticAMD
CPU family: 23
Model: 17
Model name: AMD Ryzen 5 PRO 2400G with Radeon Vega GraphicsThe obvious things:
What happens:
user1@debian2:~/linuxcnc/irq-mgmt$ sudo ./rt_setup.sh
[sudo] password for user1:
Linux debian2 4.19.0-16-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.181-1 (2021-03-19) x86_64
GNU/Linux irqbalance is running AND there are more than 2 cpus - setting up policy scriptThe script comes up with isolcpus 6,7 in grub, which is what I determined months ago and added manually and seems like it should be correct.
linux /boot/vmlinuz-4.19.0-16-rt-amd64 root=UUID=5b220cf2-b101-424f-9abb-ee2246a65503
ro initrd=/install/gtk/initrd.gz quiet
isolcpus=6,7 intel_idle.max_cstate=1 i915.enable_rc6=0my /etc/network/interfaces (after removing commented out lines and loopback):
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5). source /etc/network/interfaces.d/*
# NEW - Lenovo Ryzen desktop PC
allow-hotplug enp8s0f0
iface enp8s0f0 inet static
address 10.0.0.1Significant things I tried:
user1@debian2:~/linuxcnc/irq-mgmt$ sudo ./pinirq enp8s0f0
Cores: 8 Old CPU Mask: 0020 Set device enp8s0f0 IRQ 61 CPU mask to 0128I tried using NIC=`enp8s0f0` in place of both awks in rt_setup.sh but that does not work either (note the quotes I used!).
user1@debian2:~/linuxcnc/irq-mgmt$ sudo /etc/init.d/irqbalance status -l
● irqbalance.service - irqbalance daemon
Loaded: loaded (/lib/systemd/system/irqbalance.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2024-08-07 08:31:44 EDT; 1h 8min ago
Docs: man:irqbalance(1)
https://github.com/Irqbalance/irqbalance
Main PID: 577 (irqbalance)
Tasks: 2 (limit: 4915)
Memory: 6.3M
CGroup: /system.slice/irqbalance.service
└─577 /usr/sbin/irqbalance --foreground --policyscript=/etc/linuxcnc/lcnc_irqbalancepolicy.sh
Aug 07 08:31:44 debian2 systemd[1]: Started irqbalance daemon.section from /proc/interrupts:
60: 0 0 0 0 0 0 0 0 IR-PCI-MSI 4726791-edge xhci_hcd
61: 0 0 0 0 0 71062 0 0 IR-PCI-MSI 4194304-edge enp8s0f0
62: 0 0 0 697991 0 0 0 0 IR-PCI-MSI 4718592-edge amdgpu
Last edit: 07 Aug 2024 14:33 by CNC_Tinkerer. Reason: code formatting still butchered
- CNC_Tinkerer
07 Aug 2024 14:46 #307182
by CNC_Tinkerer
Is it possible /etc/default/irqbalance is not being used and thus not reaching our lcnc_irqbalancepolicy.sh file? I don't understand how that process is supposed to work...
- rajsekhar
- Thank you received: 12
27 Sep 2024 11:40 #310881
by rajsekhar
Replied by rajsekhar on topic Latency, error finishing read, and IRQ affinity
I downloaded lcnc_irqpolicy.sh.txt.
My NIC is "enp4s0" and Mesa ip=10.10.10.10.
I made the modification in the above file and modified file attached. Please check whether any further correction required or it is ok.
NIC=`awk 'BEGIN{nic="enp4s0 "} {if ($1=="iface") {tmpnic = $2} if ($1=="address") {if ($2 == 10.10.10.10 ) {nic = tmpnic}}} END{print(nic)}' /etc/network/interfaces`
- dbtayl
- Thank you received: 42
16 Nov 2024 15:37 #314597
by dbtayl
Replied by dbtayl on topic Latency, error finishing read, and IRQ affinity
In the interest of contributing something and not solely sucking time asking questions about problems that may well not actually be LinuxCNC's problem...
I've got a Celeron J6412 fanless PC with integrated graphics running my mill. Arch Linux, kernel 6.10.2-rt14-arch1-2-rt from the official Arch repo. Jitter is ~32000 ns- plenty good for Mesa usage, longer than I'd like. That's the result of following this thread's guidance and the usual disabling of power management in the BIOS.
My actual contribution is around video drivers. Re jitter, fbdev works great (albeit slow), the legacy Intel and KMS/modesetting drivers were terrible- latency well over 100000 ns. I'm guessing that's why you see the "nomodeset" kernel option listed. In my case, I found that disabling glamor in xorg.conf lets you use modesetting with seemingly (placebo effect?) better performance, but without any hit to jitter:
Section "Device"
Identifier "Intel Graphics"
Driver "modesetting"
#"glamor" is the other/default option
Option "AccelMethod" "none"
EndSection
Time to create page: 0.233 seconds
