Latency, error finishing read, and IRQ affinity
21 Dec 2024 22:20 - 21 Dec 2024 22:24 #317110 by itsbrian
Thanks mozmck for all this info and the bash scripts! This solved the weird issues I was running with on this new N100 PC I have.
I decided to brush up on my bash skills and update the original script.
Features
  • Checks that script is being run as root/sudo.
  • Attempts to ping the common Mesa card IP addresses (192.168.1.121 and 10.10.10.10) and if it finds a unique one it will set that as the NIC variable in the irq bash scripts. If it doesn't find one it lists the possible options for the user to choose.
    • Downside of this is that it is not as dynamic as mozmck's script if there are any Mesa card interfaces changes, but I figured people rarely change that anyways.
  • Give instructions once the script is complete.
How to run
  • Rename rt_setup.sh.txt to rt_setup.sh
  • Make sure script is executable via command line:
    chmod +x /path/to/rt_setup.sh
    Replace /path/to/rt_setup.sh to where the actual file is.
  • Run script:
    sudo /path/to/rt_setup.sh
    Again replace to where the actual path of the script is
Hopefully this helps those that are not software savvy!
Last edit: 21 Dec 2024 22:24 by itsbrian.
The following user(s) said Thank You: Lcvette, zmrdko, ChrisB_II
07 Apr 2025 05:24 #325854 by Diegot
I just discovery tuna, realtime IRQ tuning, my first impression was great.
Just test it at buster, going to bookworm now.
packages.debian.org/bookworm/tuna
The following user(s) said Thank You: rdtsc
17 Nov 2025 02:23 #338558 by BryceJ
Ran into an issue with IRQ balance after updating to trixie
Nov 16 19:34:22 hazelnut irqbalance[597]: IRQ 9 affinity is now unmanaged
Nov 16 19:34:22 hazelnut irqbalance[597]: Cannot change IRQ 14 affinity: Read-only file system
Nov 16 19:34:22 hazelnut irqbalance[597]: IRQ 14 affinity is now unmanaged
Nov 16 19:34:42 hazelnut irqbalance[597]: IRQ 123: Override ban to true
Nov 16 19:34:42 hazelnut irqbalance[1572]: /etc/linuxcnc/lcnc_irqbalancepolicy.sh: line 17: /proc/irq/123/smp_affinity: Read-only file system
Nov 16 19:37:52 hazelnut irqbalance[597]: Cannot change IRQ 135 affinity: Read-only file system
Nov 16 19:37:52 hazelnut irqbalance[597]: IRQ 135 affinity is now unmanaged
Turns out there was a bug version of irqbalance that is fixed with
github.com/Irqbalance/irqbalance/issues/308#issue-2217868587
after adding
/etc/systemd/system/irqbalance.service.d/override.conf
➜  ~ sudo cat /etc/systemd/system/irqbalance.service.d/override.conf
[Service]
ProtectKernelTunables=no
It fixed the ethernet mesa issue that was causing latency spikes
19 Jan 2026 09:28 #341571 by SrLange61
Replied by SrLange61 on topic Latency, error finishing read, and IRQ affinity
I’ve just updated to a Ali 7i92 with a Gecko540 on a old i3 pc, Plenty of ddr3 here. Running rt_setup allows the steppers to run smooth. Without it the motors appeared to be missing some steps. I had some problems running the script to find its a download error, dos2unix fixed the file to run as above.
srl
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
28 Mar 2026 00:44 #344856 by rodw
Late to the party but currently best practice is not to use irqbalance. the balancing is now managed internally in the kernel so adding a second balancer can confuse things.... but it worked here....
Time to create page: 0.138 seconds
