sorry,do you mean “Real-time Is Preemptive”?If it is, I'm trying to do it like this.I take it you ran the linuxcnc as a RIP ?
RIP means Run In Place, it's mentioned in the docs.
What method did you use to build Linuxcnc and then run an instance ?
When you built Linuxcnc did you have any xenomai develpoment files &\or libs installed ?
Did you build packagess & install the packages ?
Or did you just build Linuxcnc, run the script to setup the environment variables and run it from the command line ? Running from the menu will just run the prior installed package.
If you don't run the script to setup the environment variables or build and install new packages you will be running the prior version you installed.
