playing a g-code file using a input pin
- Ehsan_R
14 May 2024 21:39 #300618
by Ehsan_R
playing a g-code file using a input pin was created by Ehsan_R
I have several different programs that I want to connect each to an input pin so that when that pin is activated, the corresponding GCODE file will be executed.
Is such a thing possible?
- Thank you received: 2163
15 May 2024 06:03 #300654
Replied by Aciera on topic playing a g-code file using a input pin
Maybe this helps:
forum.linuxcnc.org/21-axis/51920-help-cr...c-g-code-file#295134
The following user(s) said Thank You: Ehsan_R
Time to create page: 0.563 seconds
