7i76 analog input
2 years 5 months ago #300807 by Ludwig
7i76 analog input was created by Ludwig
Hello,
I need your help again.
I can´t readout the value of the analog input from the 7i76 (see the picture).
The settings in the INI-File is as follow:
loadrt hm2_pci config=" num_encoders=7 num_pwmgens=0 num_stepgens=5 sserial_port_0=10xxxx"
Please help me to find out the problem.
I use LinuxCNC 2.9.2.
Best regards
Ludwig
2 years 5 months ago #300824 by tommylight
2 years 5 months ago #300834 by Ludwig
Replied by Ludwig on topic 7i76 analog input
Just connect 24V to TB6 pin 4 and read
net analog3 <= hm2_5i24.0.7i76.0.0.analogin3 => spindle_load.bar_spindle_load
2 years 5 months ago #300844 by tommylight
Replied by tommylight on topic 7i76 analog input
Pin 1 on header will be pin 0 in hal.
Does Mesa 7i76 have field power?
2 years 5 months ago #300848 by PCW
Replied by PCW on topic 7i76 analog input
Does digital input 0 (same pin as Analog-0)respond?
If not, that suggests a communication issue
2 years 5 months ago #300849 by Ludwig
Yes, digital input shows 1, and the fieldpower is also connect.
Time to create page: 0.318 seconds
