7i76 analog input
2 years 5 months ago #300918 by Ludwig
Replied by Ludwig on topic 7i76 analog input
any idea ?
Maybe I miss some settings in the INI or HAL files ?
The hardware locks ok. because there show the digital inputs, only the analog inputs show nothing .
2 years 5 months ago #300919 by PCW
Replied by PCW on topic 7i76 analog input
Really no idea other than possibly corrupt code on the 7I76
DSPIC.
I have seen corrupted DSPIC code on a card with output chip
damage (so 3.3V DSPIC power subjected to excess voltage)
You might try re-flashing the DSPIC with the scripts in
sserial.tgz
2 years 5 months ago #300920 by Ludwig
can you me give some advise to re-flasching please?
2 years 5 months ago #300923 by PCW
Download and unzip:
www.mesanet.com/software/parallel/sserial.tgz
Then change to the utils/linuxcnc directory and read the README file
2 years 5 months ago #300928 by Ludwig
File Name: sudomesafl...hmid.txt
File Size:7.46 KB
Ok. I re-flashing the 7i76 to swrevision 15, but still the same problem.
2 years 5 months ago #300929 by PCW
Very weird, and hard to explain, since digital input 0 gets its
value by reading the analog value internally.
I guess another possibility is an issue with the 5I24 or 5I24 firmware
Time to create page: 0.218 seconds
