7i76 analog input
2 years 5 months ago #300850 by Ludwig
Replied by Ludwig on topic 7i76 analog input
2 years 5 months ago #300851 by PCW
Replied by PCW on topic 7i76 analog input
That is a somewhat weird hardware configuration (50 pin FPGA --> 25 pin daughtercard), what does:
sudo mesaflash --device 5i24 --readhmid
show?
Also what is the 7I76 firmware version
DId you try mode 2?
2 years 5 months ago #300852 by Ludwig
I try mode 2, same result. Only there show encoder0 , encoder1 and fieldpower pin.
How to find the 7i76 firmware version?
And the 7i76 is connected to the 5i24 by DB25pin connector.
2 years 5 months ago #300853 by Ludwig
Here the 7i76 firmware version:
sudo mesaflash --device 5i24 --sserial
SSLBP port 0:
  SSLBP Version: 1.43
  SSLBP Channels: 2
  SSLBP Baud Rate: 2500000
  sserial device at channel 0: 7I76 GPIO+SPINDLE (unit 0x1000037C)
    SwRevision = 14
    HwRevision = 1
    NVBaudRate = 2.5Mb
    NVUnitNumber = 0x1000037C
    NVWatchDogTimeout = 50ms
    SOFTWARE MODE IO_Spin [index 00]
    SOFTWARE MODE IO_Ana_Spin [index 01]
    SOFTWARE MODE IO_Enc_Ana_Spin_FV [index 02]
2 years 5 months ago #300854 by PCW
That would be the parameter hm2_5i24.0.7i76.0.0.swrevision
2 years 5 months ago #300917 by Ludwig
Time to create page: 0.315 seconds
