Permission problem when loading custome hal module
  • nauman
  • nauman's Avatar Topic Author
  • New Member
  • New Member
20 May 2024 11:09 - 20 May 2024 11:24 #300996 by nauman
Hi all
I am trying to load/install one custom module using 'sudo halcompiler --install cncmod'
it is installing and I can see module in '/lib/linuxcnc/modules/cncmod.so'
But the problem is when I load this module in my config it is giving me permission problem but same module is working fine in debain linuxcnc official distribution.
Environment
Host OS: Fedora iot 38
Error:
Debug file information:
bcm2835_spi_begin failed. Are you running with root privlages??
cncmod: rtapi_app_main: Operation not permitted (-1)
./CNC-MOD.hal:10: waitpid failed /usr/bin/rtapi_app cncmod
./CNC-MOD.hal:10: /usr/bin/rtapi_app exited without becoming ready
./CNC-MOD.hal:10: insmod for cncmod failed, returned -1
11193
11206
Stopping realtime threads
Unloading hal components
cncmod: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
Unexpected realtime delay on task 0 with period 25000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
<commandline>:0: unloadrt failed
And code where error is coming in my module is
if (!rt_bcm2835_init()) {
  rtapi_print_msg(RTAPI_MSG_ERR,"rt_bcm2835_init failed. Are you running with root privlages??\n");
  return -1;
How can I set the right permission in fedora same like linuxcnc debain
I also attach linuxcnc.report for more details.
Thank you
Last edit: 20 May 2024 11:24 by nauman.
  • Moderator
  • Moderator
20 May 2024 11:45 #300997 by tommylight
Create a normal user in Fedora and run LinuxCNC from that user, usually a "sudoer" account on most distros.
Most software with direct kernel access will not run as root in most distros, due to potential to wreck havoc if misused.
the line should be sudo halcompile
notice the missing R .
  • nauman
  • New Member
  • New Member
20 May 2024 12:07 - 20 May 2024 12:13 #300999 by nauman
I have sudoer user 'cncmod' and I used 'sudo halcompile --install cncmod.c' still same problem.
more info
Install link
ls -l /dev/mem
  crw-rw-rw-. 1 root kmem 1, 1 Oct 26  2023 /dev/mem
ls -l /dev/gpiomem
  crw-rw-rw-. 1 root root 237, 0 Oct 26  2023 /dev/gpiomem
groups cncmod
  cncmod wheel
Last edit: 20 May 2024 12:13 by nauman.
Time to create page: 0.096 seconds
