Teaching Mode
23 May 2024 07:27 #301184 by riju
Teaching Mode was created by riju
Hi everyone
I'm fairly new to LinuxCNC. Went through the documentation and got the initial setup running. Now I have multiple parts that I need to drill at set locations where the markings are. I also keep adding such parts from time to time so need an easy teaching mode.
What I'm looking for is a GUI mode for teaching the machine like in robot arms.
Basically I manually move the mill to xy location, use drill command, then to second location, drill command, so on.
All this gets stored as a g-code file and this can then be run in future at any time. Note: reaching a point in an axis sometimes takes a little back and forth. what is required is the final location. For example to reach a location i'll manually sometimes go X100, X10, X-4, X1. It should store the final movement X107.
Can anyone please direct me in the right direction?
23 May 2024 13:06 #301201 by Aciera
Replied by Aciera on topic Teaching Mode
Maybe this logger could help as it can create Gcode from the logged position:
forum.linuxcnc.org/21-axis/30986-axis-po...ger?start=100#296115
Time to create page: 0.390 seconds
