Smart Serial port not detecting remote 7i87 card
- vedatech
- Thank you received: 3
31 May 2024 20:44 #302003
by vedatech
Smart Serial port not detecting remote 7i87 card was created by vedatech
I'm stumped. I have a mesa 6i25 pci card with firmware configured for five stepgens and one SSerial channel. I am trying to connect a mesa 7i87 ADC card on the serial port but I get no indication that the 7i87 card is detected.
I have checked the wiring several times. The board is getting power. When I start linuxcnc and bring up 'hal configuration' I expected to see some reference to the 7i87 - but nothing there. Is there some way to debug this systematically?
> sudo mesaflash --device 5i25 --readhmid
IO Connections for P3
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort PWM 0 PWM (Out)
14 1 IOPort None
2 2 IOPort StepGen 0 Step/Table1 (Out)
15 3 IOPort None
3 4 IOPort StepGen 0 Dir/Table2 (Out)
16 5 IOPort StepGen 4 Step/Table1 (Out)
4 6 IOPort StepGen 1 Step/Table1 (Out)
17 7 IOPort StepGen 4 Dir/Table2 (Out)
5 8 IOPort StepGen 1 Dir/Table2 (Out)
6 9 IOPort StepGen 2 Step/Table1 (Out)
7 10 IOPort StepGen 2 Dir/Table2 (Out)
8 11 IOPort StepGen 3 Step/Table1 (Out)
9 12 IOPort StepGen 3 Dir/Table2 (Out)
10 13 IOPort StepGen 5 Step/Table1 (Out)
11 14 IOPort StepGen 5 Dir/Table2 (Out)
12 15 IOPort SSerial 0 TXData0 (Out)
13 16 IOPort SSerial 0 RXData0 (In)
In HAL file:
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=0 num_pwmgens=0 num_stepgens=5 sserial_port_0=0xxxxx"
What am I missing?
14 1 IOPort None
15 3 IOPort None
In HAL file:
loadrt hostmot2
What am I missing?
- Thank you received: 5326
31 May 2024 21:41 - 31 May 2024 21:41 #302007
Replied by PCW on topic Smart Serial port not detecting remote 7i87 card
What daughtercard do you use?
Maybe an interface/pinout/polarity issue
Last edit: 31 May 2024 21:41 by PCW.
- vedatech
31 May 2024 22:48 #302013
by vedatech
Replied by vedatech on topic Smart Serial port not detecting remote 7i87 card
Its supposed to be:
hm2_5i25 < sslbp > 7i87
31 May 2024 22:53 #302014
You need a RS-422 interface with the correct pinout and polarity
between the 5I25 and 7I87. That's why I asked about the
daughtercard you are using.
- vedatech
31 May 2024 23:51 #302018
by vedatech
Ok, I should have been more detailed. The connections are:
hm2_5i25 < sslbp > < TTL-RS485 > 7i87
I'm using the TTL to RS485 translator the MESA told me to use. It and the 7i87 card have power but I don't know if the signal is getting through.
01 Jun 2024 00:12 - 01 Jun 2024 00:13 #302020
My guess is that its a wiring error of some kind
can you show the connections between the 5I25 RX and TX
signals, the RS485.422 transceiver, and the RJ-45 pins?
Last edit: 01 Jun 2024 00:13 by PCW.
- vedatech
01 Jun 2024 00:20 #302021
by vedatech
- vedatech
01 Jun 2024 00:26 #302023
by vedatech
I have to go now. I will check in later.
01 Jun 2024 02:45 #302032
Unfortunately your schematic did not get attached properly.
- vedatech
01 Jun 2024 03:09 #302033
by vedatech
Sorry, about the bad attachment. I'll try again but I think I found a problem with the differential pairs having the polarity reversed. I can't test it now but will swap the wires as soon as I get time.
Time to create page: 1.448 seconds
