Smart Serial port not detecting remote 7i87 card
03 Jun 2024 03:03 #302215 by PCW
What triggers the smart serial channel to probe any attached cards?
Does it happen on power up? When linuxcnc starts?
Yes, it happens when the hm2_xxx driver is loaded.
03 Jun 2024 03:43 #302219 by vedatech
Yes, I was confused about the wiring. It is fixed now with TX > RX, RX > TX but I still not detecting the 7i87 and I'm not even certain that the sserial port is working even though mesaflash shows the module is loaded:
> sudo mesaflash --device 5i25 --readhmid
IO Connections for P3
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort PWM 0 PWM (Out)
14 1 IOPort None
2 2 IOPort StepGen 0 Step/Table1 (Out)
15 3 IOPort None
3 4 IOPort StepGen 0 Dir/Table2 (Out)
16 5 IOPort StepGen 4 Step/Table1 (Out)
4 6 IOPort StepGen 1 Step/Table1 (Out)
17 7 IOPort StepGen 4 Dir/Table2 (Out)
5 8 IOPort StepGen 1 Dir/Table2 (Out)
6 9 IOPort StepGen 2 Step/Table1 (Out)
7 10 IOPort StepGen 2 Dir/Table2 (Out)
8 11 IOPort StepGen 3 Step/Table1 (Out)
9 12 IOPort StepGen 3 Dir/Table2 (Out)
10 13 IOPort StepGen 5 Step/Table1 (Out)
11 14 IOPort StepGen 5 Dir/Table2 (Out)
12 15 IOPort SSerial 0 TXData0 (Out)
13 16 IOPort SSerial 0 RXData0 (In)
However, hal configuartion only shows the StepGen pins and everything else is just IOPort. How can I check to set if SSerial is actually working?
03 Jun 2024 03:46 #302220 by vedatech
I have to get some sleep but I'll check again in the morning
03 Jun 2024 18:52 #302259 by vedatech
All's well that ends well. The 7i87 card is now detected and its pins and parameters are visible in hal configuration.
Just a series of stupid wiring mistakes and wrong assumptions on my part. The final thing that got it working as realizing that TXEN doesn't mean TX Enable it means TX Enable NOT. Once I grounded it I saw nice clean differential pulses on the output of the TTL-RS485 converter.
Now I can work on the software.
Thanks for your help PCW.
03 Jun 2024 19:03 #302260 by vedatech
One new issue though. The 7i87 works fine in mode 0 but linuxcnc fails if I set it to mode 1 or 2. I only want to use mode 0 but any idea why this happens?
03 Jun 2024 19:17 #302262 by PCW
Not sure, what does your config line look like?
03 Jun 2024 21:04 #302270 by PCW
Yes there's a bug of some kind with the 7I87 and modes >1 with recent
LinuxCNC versions. I will take a look at this later this week.
Time to create page: 0.162 seconds
