controller and motors not fully communicating
- foam man
- Thank you received: 5
28 Jun 2024 03:32 #303952
by foam man
controller and motors not fully communicating was created by foam man
HiI got a small DIY milling machine from a friend who bought it from some guy a couple of years ago. When I plug everything in, Linux opens up, and I can jog the axis on the screen, the ini folder looks like it's set up, the controller turns on, but the motors don't jog even though they get warm. I'm wondering if there's some communication issue and where to start. I have run a foam cutter with Linux and know the tiniest bit about this, but not sure where to start diagnosingHelp is appreciatedThanks
- Thank you received: 5326
28 Jun 2024 03:45 #303953
Replied by PCW on topic controller and motors not fully communicating
I would do some simple electrical checks
like seeing if the direction signals going to
the step drives change from 0 to 5V
(or vice-versa) when you jog in opposite
directions.
directions.
- foam man
13 Jul 2024 19:08 #305105
by foam man
Replied by foam man on topic controller and motors not fully communicating
sorry for not replying sooner. usually I get an email when a reply comes in. i also have not had time to tinker but i will check that out
- foam man
14 Oct 2024 04:25 #312028
by foam man
Hi
I know it's been months since I did my last post but i've been fiddling with this thing in my spare time. just to clarify, I have a Probotix box with motors, which I plugged into the computer running the mill and I could jog those motors. when I checked the voltages to the motors on the control box thats not working, I found the red and black have 22ish, the white and gray have the same but when I jog it doesn't change. What brings that signal to the driver. Thanks
- Online
- Thank you received: 7478
14 Oct 2024 10:23 #312050
Replied by tommylight on topic controller and motors not fully communicating
Is that the box with L297 and L298 chips on it?
- foam man
15 Oct 2024 18:24 #312189
by foam man
I apologize for being so naive, but where would I find these chips
- Online
15 Oct 2024 20:37 #312198
The chips should be in the control box.
Pictures of it, inside?... I have a Probotix box with motors,...
- foam man
16 Oct 2024 03:20 #312218
by foam man
In this box?
- Online
16 Oct 2024 13:50 #312266
That is a good controller, so what is not working on what controller?
- foam man
16 Oct 2024 16:48 #312278
by foam man
the Probotix controller works well, it's the other one (The first pictures) that does not work. the wires coming to the motors are getting power but the voltage does not change when I try to jog. I'm wondering if whatever wires bring the move signal are not doing their job. Originally I thought maybe it was a programming error, but if the Probotix box works...
Time to create page: 0.562 seconds
