Getting an error on starting a machine
2 years 2 months ago #308068 by __Tom
Hello, hope someone of you can help me.I have 2 machines defined on one mesa 7i76e card a mill and a plasma cutter. Both was working well until an error came up. In the most cases an reboot of hard and software fixed all the troubles I had so far. But this one seams to be different. On rebooting on both of the machines I get the same error (please see the attached file) Hopefully I have no hardware damage.Thanks for your afford in advance. BR. Tom
2 years 2 months ago #308070 by PCW
That error means there is no communication with the 7I76E
what does the command
ip a
report?
2 years 2 months ago #308074 by __Tom
the output from command "ip a" and "ping 10.0.0.10"
2 years 2 months ago #308075 by PCW
You would need to
ping 10.10.10.10
To check connectivity to the 7I76E
2 years 2 months ago #308077 by __Tom
Oh yes my fault, 10.10.10.10 returns nothing.
So I suppose the mesa is gone.
2 years 2 months ago #308079 by PCW
Could be cabling problem but the "ip a" report shows
the link as up,  could also a be a host PC issue, or be a
7I76E issue.
What do the LEDs on the 7I76E RJ45 connector show?
Time to create page: 0.281 seconds
