Getting an error on starting a machine
2 years 2 months ago #308091 by __Tom
yes to 10.10.10.11
2 years 2 months ago #308098 by PCW
The lack of yellow (100BT) LED illuminated the RJ45
suggests a problem with the 7I76E Ethernet interface
or the host Ethernet interface.
I would try a known working  Ethernet connection, and if you
do not get both Green (activity) and Yellow (100BT) LEDs
illuminated on the 7I76E RJ45 connection, I would return the
7I76E  for warranty repair. Note that especially for plasma systems
it's important to ground the frame ground connection on the 7I76E.
2 years 2 months ago #308103 by tommylight
ip a
If you only changed from 10 to 11 it will not work
Change to 10.10.10.11
2 years 2 months ago #308114 by __Tom
Thanks a lot for your afford.
Time to create page: 0.316 seconds
