Getting an error on starting a machine
2 years 2 months ago #308081 by __Tom
Changed the network cable, same result.
Led shines green
2 years 2 months ago #308084 by tommylight
The PC has the wrong IP address, it should be
10.10.10.11
not
10.0.0.10
After fixing that, check with
ping 10.10.10.10
if the Mesa is set for a static IP of 10.10.10.10 see manual.
2 years 2 months ago #308085 by PCW
Can you check if get any LEDs illuminated on the 7I76E RJ45 connector
with the Ethernet cable unplugged?
2 years 2 months ago #308087 by __Tom
please see attchments
2 years 2 months ago #308088 by __Tom
I changed the PC addr. to 11, same behave as before, no succ.
2 years 2 months ago - 2 years 2 months ago #308090 by Aciera
Just to be on the same page you changed the PC IP-address to this?
10.10.10.11
Last edit: 2 years 2 months ago by Aciera.
Time to create page: 0.348 seconds
